Hi all,
Okay, I've got a cylindrical water tank that has a supply in fitting, a supply out fitting and a global fitting (acting as the vent).
In one tank type, the fittings are at a height of 36" and the pipes all connect up just fine.
If I decide I need a bigger tank, I change the family to a larger size so the height goes up to 40" and get the following message: "The family is connected in a duct/pipe network and can no longer keep the connectivity. Disconnect the family from the network?"
I only have the option to disconnect or cancel. Is there any way to make the pipe stay connected to the connectors when the family changes heights? It seems counter-intuitive that I have to go back into the family and reconnect the pipe to the connectors at the new height in the family.
Is this a problem with a workable, parametric solution?
Thanks!
