Results 1 to 10 of 12
Thread: Need a script to (xx)
    100 Club aharris's Avatar
    2003-08
    Lubbock, TX
    106
    Default Need a script to (xx)
    I'm needing some sort of script that will put ( ) around numbers. I don't think I have any over 99, so if it worked with 2 digits it would save me a ton of time.
    Example:So I've got an existing number of 25 and I need it to read (25).
    Thanks!!!
    The only difference between me and a madman is that I'm not mad.
    SALVADOR DALI
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,215
    Default Re: Need a script to (xx)
    Do you want something like this one?
    (setq num 25)
    (setq res (vl-princ-to-string (read (strcat "(" (itoa num) ")"))))
    or:
    (setq num "25")
    (setq res (strcat "(" num ")"))
    ~'J'~
    "The whole problem with the world is that fools and fanatics are always
    so certain of themselves, and wiser people so full of doubts."
    Bertrand Russell
    2003-08
    Lubbock, TX
    106
    If I understand the code correctly, neither...???
    Let me expand it a little more: I've got text numbered 1 through 99 through out the drawing, multiple times. Now I need to change 1 to 99 to (1) to (99). So, I guess I gave a bad example, 25 was just a number, but I've got numbers from 1 all the way to 99. I even have 23-1, 23-2, 23-3 numbers or even 23-1A in a few places. But to keep the code simple, I'd be happy with .lsp program that does 10 to 99.
    SALVADOR DALI
    2005-08
    1,043
    Here is an old one you can change to suit you needs.
    (defun c:PAR(/ tset1 tlng1 to1 to2 tx1 tx2 ntx to3)
        ; Adds parenthes to ending and beginning
        (command "_.undo" "_end")
        (command "_.undo" "_group")
        (prompt "\nSelect text to put parenthesis around: ")
        (setq tset1 (ssget '((0 . "*TEXT"))))
        (if (= tset1 nil)
            (setq tlng1 0)
            (setq tlng1 (sslength tset1))
        (while (/= tlng1 0)
            (setq to1 (ssname tset1 0))
            (setq to2 (entget to1))
            (setq tx1 (assoc 1 to2))
            (setq tx2 (cdr tx1))
            (setq ntx (strcat "(" tx2 ")"))
            (setq to3 (subst (cons 1 ntx) tx1 to2))
            (entmod to3)
            (entupd to1)
            (ssdel to1 tset1)
            (setq tlng1 (1- tlng1))
    2003-08
    Lubbock, TX
    106
    I got an error loading it.
    ; error: bad argument type: numberp: nil
    SALVADOR DALI
    2005-08
    1,043
    Can you post what the command lines says when you run the code. Are you able to select objects? I just tried it, and it worked when I selected something and when I didn't, so I'm not sure why it errored one you.
    2003-08
    Lubbock, TX
    106
    Well, maybe I should start off by saying after 20 years in AutoCAD, I still don't really do .lsp. I know just enough to hack someone elses code, but to start new, I just can't do it. Html code, I'm not bad at that .
    Anyway, this is the error I get:
    Command: (LOAD "PAR")
    Oh, also running AutoCAD MAP 2007 on this computer.
    SALVADOR DALI
    2005-08
    1,043
    You can just copy/paste the code to the command line, and the just type 'par' at the command line to run it. If you want to put it in a file, then you need to copy/paste it to a file, and save the file with a .lsp extension, and then load the file. If the file is in the search path, then you can just type '(load "filename.lsp")' if it's not then you need to type in the whole path.
    Hope the helps.
    2003-08
    Lubbock, TX
    106
    Quote Originally Posted by T.Willey View Post
    Hope the helps.
    Well, that did the trick...couldn't remember if I could c/p code directly to the command line or not. However, I did open Notepad, c/p code into it. Save the file as par.lsp (okay, first I had to go to a dos command and rename it from par.lsp.txt to par.lsp). I moved the file to where the dwg is located and did the load thing.
    Oh well, if I can't load it from lsp, I'll c/p.
    Thanks for your help!!!!!!!!!!!!!!!!!!!!!
    SALVADOR DALI
    2005-08
    1,043
    Another things you could do is make the lisp file you did, then in acad type 'appload'. Then in the bottom right, the Startup Suite, you can add your file there so it will load with every drawings.
    You're welcome. Glad you got it to work.
  1. Script Help
    By geoffrey.m.reynolds in forum AutoCAD Customization
    Last Post: 2012-03-20, 10:24 AM
  2. Script pro
    By plarson.118418 in forum AMEP General
    Last Post: 2008-12-18, 06:30 PM
  3. script help
    By mark.momper in forum AutoLISP
    Last Post: 2008-02-22, 06:48 PM
