Thread: modifying blocks with multiple instances
    2006-11
    Martinsburg, WV USA
    186
    Default modifying blocks with multiple instances
    I have dynamic blocks that may be inserted well over 100 times in a drawing. is there any good way to deal with modifying the base block without having to wait so long for the drawing to come back when i save and close block editor? sometimes it never comes back and i have to force Autocad to exit, re-open and start over..
    I could stop if I wanted to artisteroi's Avatar
    2007-02
    Tampa, FL
    269
    Default Re: modifying blocks with multiple instances
    Quote Originally Posted by james.126519 View Post
    first save as a new file
    use the quick select to select all instances of the block, go to edit menu, copy with base point, 0,0 enter.
    now delete the selction of blocks. they no longer exist in model space. There is still an instance in the database however.
    open the block editor and browse the window to the block you want. make the changes you want in the editor and save the block and close the editor.
    now go back to the edit menu and paste, insertion point 0,0. cad will get the new block definition from the database to re-insert the items. it will ask you "redefine the block" say yes. you should now have the new block modified for all instances.
    this can tax the database, so make sure you save first. if the file is very large it can cause memory problems. you still have to wait for it to update but since you are already in model space there shouldn't be problems with the drawing coming back. good luck
    Portland, OR area
    90
    Since memory appears to be an issue I would take the extra step to PURGE the block definition after copy with basepoint then save the original file.
    In a new drawing paste the blocks and make the needed change to the block in the block editor and update the block definition. Select all the blocks and copy with basepoint and insert into the original drawing. This way you are dealing with a smaller file size so memory isn't as much of an issue when updating the block definition.
    Nancy
    Quote Originally Posted by artisteroi View Post
    2007-02
    Tampa, FL
    269
    that won't work though, if you purge the block then theree will be no definition in the database, so nothing to alter in the block editor
  1. Communication through multiple instances of Autocad
    By Serhan_BAKIR in forum AutoLISP
    Last Post: 2012-02-21, 02:28 PM
  2. 2010: Modifying same parameter in multiple blocks
    By Dewey.Lakey287889 in forum AutoCAD General
    Last Post: 2011-07-27, 02:18 PM
  3. I want to allow multiple instances in the same place
    By timsea81 in forum Revit MEP - General
    Last Post: 2010-10-27, 01:02 PM
  4. Multiple instances
    By jjanis in forum AutoCAD General
    Last Post: 2010-01-22, 09:54 PM
  5. Multiple Instances of ACLT2009
    By cad.192369 in forum AutoCAD LT - General
    Last Post: 2008-10-07, 10:28 AM
