Results 1 to 1 of 1
Thread: Concrete slab won't cut Concrete Foundation Wall
    100 Club BigBadBIM's Avatar
    2007-07
    Madison, WI
    185
    Default Concrete slab won't cut Concrete Foundation Wall
    I can't get a Conc SOG to cut a Conc Found wall. When I finish the floor sketch I am asked if I want to join/cut the overlapping volume of the floor from the wall and I click yes. Then when I look at the section the slab is joined to the wall (I assume because of same material.) When I change the thyp of floor to a truss structure the wall cuts fine.
    When I sketch the floor, if I pick the First floor walls with the "pick walls" command, I don't get the option to join/cut the overlapping geometry (since there isn't any between that wall and the floor. I also can use the cut geometry tool to cut the slab from the foundation wall at that point.
    Any pointers? I want the Conc Slab to display similarly to the truss floor. See pics below.
  1. How do I turn off the concrete slab?
    By thenickster_7 in forum Revit MEP - General
    Last Post: 2010-04-29, 06:32 PM
  2. Editing concrete parameters to show concrete type
    By Buzter in forum Revit Structure - General
    Last Post: 2010-02-08, 04:08 PM
  3. Concrete floor slab cantilever
    By amsterdamn in forum Revit Structure - General
    Last Post: 2009-04-23, 06:11 PM
  4. Replies: 8
    Last Post: 2007-05-17, 02:37 PM
  5. Concrete slab recess blues
    By Tib in forum Revit Structure - General
    Last Post: 2007-04-23, 11:59 AM
