Thread: how to delete solprof layers
    2007-02
    Bellingham, WA & Kuparuk, AK
    20
    Default how to delete solprof layers
    Is there a way to delete unused solprof generated layers?
    2007-07
    Jo'burg SA
    4,344
    Default Re: how to delete solprof layers
    SOLPROF generates blocks, the entities inside these blocks are on these layers. So:
    1. Explode the block / delete it, depending on what you want
    2. If exploded, change the lines to other layers
    3. Purge the block definition
    4. Then delete the layer(s) in Layer Manager, or Purge it.
    2007-02
    20
    Sorry, but I've been there and done that and the multiple PH- and PV- layers which have no entities existant will not purge and cannot be deleted using layer manager.
    2007-07
    Jo'burg SA
    4,344
    As a last resort use the LAYMRG command:
    1. Draw a line on each of the layers you want removed. Draw another line on the Layers you actually want.
    2. Type LAYMRG at the command prompt - this is the same as the Layer Merge choice under Format --> Layer Tools --> Layer Merge (for 200 or Express --> Layers --> Layer Merge (pre 200
    3. Select the lines on the layer(s) to be merged into the wanted layer.
    4. Press Enter
    5. Pick one of the lines on the layer you want this to appear on.
    6. Answer Yes to the prompts for purging.
    7. Repeat 2 to 6 for any other layers you want to "move" the SOLPROF layers onto.
    It used to be an Express Tool, but it's now incorporated into Vanilla 2008. However, be careful, the non-Express version sometimes gives me errors in the DWG.
    0,0,0 The Origin
    8,029
    That's going to be difficult with no entities.
    Search the net for "Superpurge".
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
  1. Delete layers?
    By linying-d in forum VBA/COM Interop
    Last Post: 2009-12-18, 03:18 PM
  2. Delete Layers
    By mboyer in forum VBA/COM Interop
    Last Post: 2009-04-28, 02:07 PM
  3. Unable to delete Layers, there is nothing on those Layers
    By smdin79 in forum AutoCAD LT - General
    Last Post: 2005-11-02, 04:21 PM
  4. CANNOT DELETE LAYERS
    By jeff.garr in forum AutoCAD General
    Last Post: 2004-12-15, 01:56 PM
  5. Layers that won't delete
    By LT.Seabee in forum ACA General
    Last Post: 2004-12-11, 02:13 PM
