Thread: Productstream 2009 problems with floating licenses
    2008-08
    5
    Default Productstream 2009 problems with floating licenses
    Hi @ll,
    I have the following problem:
    In our CAD environment is PSP 2009 installed with floating licenses. The software is working fine on desktops. The problem we have is that if we install PSP2009 on a laptop then we get an error message that the license server could not be found. ( see attachment ). Inventor / AutoCAD and PSP is licensed by the same license server with the same license file. Inventor / AutoCAD is working with that licenses server.
    Is there anybody out there who can help me with this problem ? Thanks in forward for your efforts and support.
    // the attachment is in german; but for translation: The floating server is not available .. try again later or contact your admin...
    2008-08
    5
    Talking Re: Productstream 2009 problems with floating licenses
    Ok, I solve the problem!
    2003-04
    13
    Default Re: Productstream 2009 problems with floating licenses
    Productstream is a network licenses by default.
  1. ACA 2009 Problems
    By ryant in forum ACA General
    Last Post: 2010-04-06, 02:46 PM
  2. Productstream 2009 Lizenzproblem
    By bjoern.reinhardt in forum Deutsch - Autodesk Vault / Autodesk Productstream
    Last Post: 2008-09-10, 07:22 AM
  3. AutoCAD LT 2009 working with floating viewports in Paperspace
    By RockDog in forum AutoCAD LT - General
    Last Post: 2008-06-24, 02:50 PM
  4. Dynamic/Floating Licenses available for AutoCAD LT?
    By rgorman in forum AutoCAD LT - General
    Last Post: 2007-03-30, 01:39 PM
  5. Stand Alone Licenses to Network Licenses
    By TroyGates in forum Revit Architecture - General
    Last Post: 2003-07-23, 05:18 PM
