I attached a dwg to show what I mean.
The dwg has table ( 1row 1 column). Nothing else.
If you check the blocks in the dwg you will see that there are more than 10 blocks in the drawing.
I use purge but they are not deleted.
The only way to get rid of them is to explode the table and then purge.
I do not want to explode the table in my original drawing.
Is there another way to purge the blocks ? Why this is happening anyway ?
Thanks
