Thread: piers and posts
    2008-05
    Honolulu
    334
    Talking piers and posts
    did some search on this
    but how do you create a pier with an adjustable post...
    i tried GMs in a group... but probably not best
    epesically if posts are different lengths... but all piers the same.
    ray
    2006-05
    836
    Default Re: piers and posts
    You should just nest the foundation family into the column family.
    This will give you the ability to use the object.
    Make sure the family is shared so you can still access the pier options.
    2008-07
    Brisbane (Ex. Swedish)
    349
    You can also create a ref plane that you link the top of the pier to and the bottom of the post to.
    But I would like to be able to attach a column to the top of another column (say attach a steel column to the top of a concrete column) in similar to that you can attach a column to a slab.
    Cheers
    J
  1. Helical Piers
    By hhall in forum Revit Structure - Families
    Last Post: 2013-05-30, 01:54 AM
  2. Footings and piers
    By Galadriel in forum Revit Structure - General
    Last Post: 2008-12-23, 08:18 AM
  3. Other issues with foundations and piers
    By david_peterson in forum Revit Structure - General
    Last Post: 2006-03-08, 03:37 PM
