Results 1 to 10 of 10
Thread: Showing line thickness clearly
    2006-02
    Minnesota, USA
    13
    Default Showing line thickness clearly
    In my drawings we use 2 differnt line thicknesses, default and a polyline with a global width of .035. Our new customer is having difficulty telling the 2 line thicknesses apart. I can see it plainly having looked at these types of drawings for 8 years, but they are having problems. A co-worker's prints and monitor show the differences clearly, but we cannot figure out what settings could be different. Both of our lineweight settings are defaulted to .25 mm. I have also checked the ctb file and they are similar to my co-worker's as well. I know there is something simple I am missing.
    Any suggestions????
    All AUGI, all the time kathy71046's Avatar
    2004-07
    Perth Australia
    736
    Default Re: Showing line thickness clearly
    Your customer can't tell on printed? or are they using autocad?
    If on cad, is lineweight set to on?
    Kathy Taylor
    Senior Structural Draftsperson & Proprietor
    TaylorCAD
    www.taylorcad.com.au
    I don't suffer from insanity - I enjoy it!
    Revit User Phase 3, 4, 5, 4, 3, 5, 4.....
    2006-02
    Minnesota, USA
    13
    Customer can't tell on hard copies.
    2004-08
    Iron Station, NC
    3,198
    could you post a drawing containing a sample of these two lines side by side?
    2006-02
    Minnesota, USA
    13
    Here is an example.
    2004-08
    Iron Station, NC
    3,198
    are you certain they are using the same plot table setting as you are?
    2006-12
    Big "D"
    3,711
    The .CTB file shouldn't matter since the thickness is assigned to the pline, right? Maybe the guy is exploding the plines, therefore making them lose their thickness. Just a thought.
    2004-08
    Iron Station, NC
    3,198
    Quote Originally Posted by dzatto View Post
    it would matter for the line, it could be that the line is being printed with the .35 width. but from my past experience, the difference between .25 and .35 is difficult to see unless they are side by side, and even then it is hard to tell on a hard copy.
    2015-12
    2,095
    Quote Originally Posted by ccowgill View Post
    Especially when a lower-quality printer is used. For letter and ledger sized prints, the number of easily distiguishable line weights is pretty small. Our good printer can hit 4 or 5 lineweights, our not-so-good ones are pretty much limited to 3 (thin, medium, and thick).
    2007-09
    Federal Way, Washington
    41
    This may seem obvious, but did the guy having the trouble perhaps overlook the ctb? Maybe he didn't load yours and has the wrong one selected? Long shot...but a possibility.
  1. Wall thickness not showing correctly in profile
    By egmoreno in forum AutoCAD Civil 3D - Pipes
    Last Post: 2009-01-09, 06:58 PM
  2. LIne thickness question...
    By Ogre in forum AutoCAD General
    Last Post: 2007-08-21, 03:43 PM
  3. Different Line Thickness's between Layouts
    By neilcheshire in forum AutoCAD LT - General
    Last Post: 2006-11-24, 06:46 AM
  4. Changing Line Thickness
    By .chad in forum ACA General
    Last Post: 2006-05-03, 06:00 PM
  5. Line thickness
    By methost in forum AutoCAD General
    Last Post: 2005-10-03, 02:28 PM
