Results 1 to 8 of 8
Thread: JPG exploded
    2001-12
    Seadrift, Texas
    21
    Default JPG exploded
    Is there a way to insert a JPG (BMP, TIF, GIF,or PNG) file & explode it into lines?
    Turlock, CA
    6,420
    Default Re: JPG exploded
    All those file formats are called "raster". They are made by coloring every single pixel, IOW, they are just dots. To get line work from them, you have to "trace" over the pixels that appear to your eye as a line. This is called "vectorizing". AutoCAD Raster Design can do this.
    C:> ED WORKING....
    LinkedIn
    2001-12
    Seadrift, Texas
    21
    I thought I had done it once a long time ago; guess not.
    Thanks
    Earth
    9,805
    There is nothing that can really "Explode" a raster image into vectors. But I thought I would mention... Dotsoft has an image import tool that imports images like AutoCAD did pre-R14 (as a collection of SOLID entities). This might be worth looking at... or if you have a copy of R13 handy...
    R.K. McSwain | CAD Panacea |
    I could stop if I wanted to Comach's Avatar
    2005-03
    Scotland
    286
    If you download a trial copy of Adobe Illustrator you should be able to load the image file and do a trace which can then be saved out of Illustrator as a DWG file.
    Illustrator is also useful for reverse engineering a PDF file that was originally created from a cad drawing.
    2003-11
    450
    There is a free program called Wintopo that will vectorize raster files.
    2008-06
    56
    CorelDraw also does this, PDF originals come out the cleanest.
    2009-05
    2
    Quote Originally Posted by hughrjt View Post
    i agree. illustrator's a very handy program to learn.
    beware of a lot of 'automatic' vector tracing programs, the end result isn't always going to turn out to be something that's easy to work with in autocad.
    i have always manually traced raster images in either illustrator or autocad itself (depending on what i'd like to 'extract' from the image). this is beneficial when you want complete control over how the objects will behave in your drawings. there's nothing worse than vectorizing a raster image and then trying to work with a polyline with tens to hundreds of vertices.
  1. 2012: DWF markups appear exploded
    By troy.crandell635379 in forum Revit Architecture - General
    Last Post: 2011-10-18, 04:04 PM
  2. Exploded Leaders
    By CCR in forum AutoCAD General
    Last Post: 2009-03-10, 08:16 PM
  3. Exploded In CAD!
    By winnwgomez in forum Revit - Plotting/Printing/Exporting
    Last Post: 2008-09-17, 01:55 PM
  4. exploded views?
    By mmarzluf in forum AutoCAD General
    Last Post: 2008-02-06, 09:43 PM
  5. Exploded Axonometric
    By j_tancharoen15 in forum Revit - Student Support
    Last Post: 2007-05-10, 06:19 PM
