jjochum
I am running Autocad 2004 and trying to build blocks of PLC I/O cards to quickly insert into drawings. I've got the block so it will prompt for a Rack number and a Slot number and insert them as attributes above the I/O card. Is it possible to have the point addresses change automatically to match the Slot number? I've tried just copying and pasting the Slot number and putting it in each point address, but then it prompts me to enter the Slot number for each point. I would like to have it change automatically. I'll attach a .dwg that helps explain what I want. If need be I can break up the Point Address into multiple pieces. I would only need the X in the Point Address I:X/00 to change. It's range would be 1-99. The max number of Point Addresses is 16. If you need any more info, please let me know. Thanks in advance.
