Thread: Pedit and sweeping in 3D
    Default Pedit and sweeping in 3D
    I want to make the sweeping shown at the attached images. I try to join three lines in x,y,z axises but it's not possible. What should I do?
    Default Re: Pedit and sweeping in 3D
    Try out my PEDIT3D.lsp
    Free download from
    www.black-cad.de
    Good luck
    Jochen
    Thank you.
    2006-12
    Big "D"
    3,709
    You can also draw a 3D polyline first, then use that pline as a path to extrude the shape over. Then it will all be connected.
    Why is it called common sense when it is so rare?
    RevitForum.org
    2006-01
    202
    Quote Originally Posted by dzatto View Post
    That is exactly how the pedit3d command that Dr Schulz wrote works.
    We have used it at our company for years with great success and I personally would not be able to go more than a day without using it!
    If using it, remember to ERASE, "P" immediately after running the command to erase your original objects which still remain in the drawing.
    This command also works as best as is possible given AutoCAD's restrictions in also being able to join arcs to 3d polylines/lines by facetting them.
  1. Sweeping and Joining Masses
    By GerG in forum Revit - Student Support
    Last Post: 2010-10-12, 09:41 AM
  2. On Sweeping Arched Openings
    By BillyGrey in forum Revit Architecture - General
    Last Post: 2005-08-20, 03:52 PM
  3. Sweeping Issue
    By Jason in forum Revit Architecture - General
    Last Post: 2003-08-29, 02:16 PM
