Results 1 to 8 of 8
Thread: changing values in levels
    2008-05
    Honolulu
    334
    Talking changing values in levels
    have entire building that needs to be raised 6.54' thot this could be done by just changing the grade elevation which is now 0.0' but when i put in the new value most of building goes up but much does not
    thot I could select everything and move it but constraints exist which only allow horizonal movement not vertical
    tough questions today
    ray
    AUGI Addict Andre Carvalho's Avatar
    2006-06
    Toronto, ON
    2,386
    Default Re: changing values in levels
    Go to Tools > Project position / Orientation > Relocate this project > you will notice the cursor will change to the move one. Pick anywhere and enter the distance you want to move up. Once moved, select one of your level marks > Properties > Edit/New > Change Elevation Base from Project to Shared.
    Andre Carvalho
    2008-05
    Honolulu
    334
    ok, that was a wow fix
    I have just added you name to my will ....
    ray
    2002-02
    St. Louis, MO
    4,688
    Quote Originally Posted by ray salmon View Post
    ray
    Kind of a fix.
    What you'll want to do for future projects is straighten out the template. Do you use 100'-0" as a project reference elevation? If so - move your level lines up in the template 100'. Now they will read 100'-0" for the project setting. Then when you know the true floor elevation you can use relocate project to "move" it up to the correct shared elevation. You ca put in two level lines styles - one can read project level and the other can read the real survey level. It would be nice if this were a instance per view setting on level lines rather than a type aprameter, but it is still usefull.
    Don't drink the Kool-Aid...
    Aaron Rumple, AIA
    2005-12
    566
    Aaron or another person:
    This post has solved the same problem for myself.
    One more question: Is there a way to change the units in level heads from architectural to decimal feet, for instance? It seems the level head Elevation field reports a length value and prints it using project units.
    2003-08
    Vancouver, BC Canada
    3,394
    This one is buried deep.
    Select the level datum head in your project browser. If you aren't sure which on it is you can go to the type properties of your level datum to find it.
    Once there you can edit the settings by selecting the label. Check out the image.
    ____________________________
    Dimitri Harvalias LEED AP
    Summit BIM Consulting
    BIMblog.ca
    I was never just a CAD monkey, so I refuse to be a BIMpanzee!
    A BIM without the 'I' is just a BM - those in the medical profession know what that amounts to
    I could stop if I wanted to nsinha73's Avatar
    2006-09
    CA
    460
    Talking Re: changing values in levels
    ray
    LOL!!!!!!!!!!!
    It is much easier to be an Obstacle in Revit then a Resource.
    2008-08
    2
    If you move your level lines, your building moves in relation to site, which is fixed on shared coordinates (sea level). Isn`t it possible just to define another project base point?
  1. Changing Instance Parameter default values
    By mthiessens in forum Revit Architecture - General
    Last Post: 2008-07-30, 10:33 PM
  2. Random Changing Levels
    By angus.110169 in forum Revit Architecture - General
    Last Post: 2008-07-16, 11:39 PM
  3. Changing Associated Levels
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2006-10-07, 06:33 AM
  4. Changing levels
    By Steve Jager in forum Revit Architecture - General
    Last Post: 2006-10-06, 06:32 PM
  5. Changing Clipped View Front & Back Values
    By 3D Jack in forum AutoLISP
    Last Post: 2005-07-01, 03:54 AM
