Results 1 to 10 of 15
Thread: Everything turning grey
    100 Club Beancud's Avatar
    2007-10
    Down Under
    189
    Red face Everything turning grey
    Hi folks,
    I was wondering if anyone has a solution to this. We have several drawings thats having an issue with plotting.
    When we plot or print or pdf a drawing the entire sheet turns into light / faint grey - almost like shadowy effect.
    I have checked the CTB, line types, Pen styles, plot by colour etc etc. Everything is pre assigned to our office set up. The drawings print perfectly from my pc with the right line thickness and pen darkness. However when my colleague try to print it everything turns grey.
    I have checked for consistency, apart from what I have noted above - same version of drawings, autocad, plot configurations. It looks like AutoCAD is ignoring everything and printing the drawings out in very faint lines.
    I am no sure what gives, the strange thing is when we open another drawing within the same set and print it comes out fine, so we go back to our no good drawing and print with previous print setting, the drawing looks fine.
    So afterwards I have re inserted the page style and plot style from the drawing thats working properly, but it still comes out grey and faint.....
    I am now looking at template issues, some unkown plot command running... any advice / solution will be apreciated!
    2005-12
    160
    Cool Re: Everything turning grey
    Quote Originally Posted by Beancud View Post
    Hi folks,
    How about the Plot Preview, what you see in the preview, is it grey or colorfull?
    Check the Page Setup for the plotting in the Plot dialog box, you may select the Page Setup which plot in grey color, try other Page Setup, Preview before you plot, this always is a good habit to prevent the wrong plotting
    Jack Cheong
    2007-10
    Down Under
    189
    Default Re: Everything turning grey
    Quote Originally Posted by jack_fs2002 View Post
    Jack Cheong
    Yes I do that everytime, even when I preview it turns grey.
    I have rigolosly checked the pagesetup and the CTB setting which is assoicated to it. This shouldn't be a pagesetup issues as pagesetup changes sheet size and utilize the associated CTB format.
    The plot style is set to plot by pen colour yet this drawing seems to ignore everything and greys everything.
    I have a feeling my co-worker worked at home on his AutoCAD 2009 which done some funny thing to it.....
    2002-01
    I live on the Moon
    52
    I have had the something similiar happen to me....
    I have objects in my drawing that are on separate layers, with different layer colors but when I do a print preview (before my plot) everything changes to grey.
    You could see my posts if you looked at user name and search posts by:
    Have you come to a solution?
    All AUGI, all the time Richard.Kent's Avatar
    2001-01
    Albuquerque, NM, USA
    621
    MVIEW, Shadeplot, As Displayed, all ...
    Maybe this is the solution.
    Certifiable AUGI Addict Robert.Hall's Avatar
    2004-07
    Detroit Michigan
    2,510
    Are you using a .pc3?
    0,0,0 The Origin
    8,027
    Page setup manager - top right - under the plot style table is a check box marked - display plot styles. If it's checked, uncheck it.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2002-01
    I live on the Moon
    52
    Richard.Kent.... this does not work, but it was great learning a new command. I got my sheet set to the way it was supposed to look, but when I did the print preview, everything went back to grey...
    2002-01
    I live on the Moon
    52
    Robert.Hall... I am not using .pc3.... should I?
    2002-01
    I live on the Moon
    52
    Jaberwok.... My Plot Style Table is set at NONE... in fact, I dodn't have a plot style, never used them.
    There are several dozen different plot styles listed, and I can get same of the items to plot in their true color, but not all, by selecting "true colors" plot style.
    But thanks for the suggestion...
  1. Grey box around keynotes
    By dpamark in forum ACA General
    Last Post: 2010-03-12, 06:58 PM
  2. Need to set everything in this dwg to Grey
    By dixie1222 in forum AutoCAD General
    Last Post: 2008-11-20, 08:05 AM
  3. Replies: 4
    Last Post: 2008-01-13, 06:56 PM
  4. Rendering in Grey????
    By Les Therrien in forum Revit Architecture - General
    Last Post: 2006-12-04, 11:56 PM
  5. UNDERLAY IN RED RATHER THAN GREY?
    By ykang in forum Revit Architecture - General
    Last Post: 2006-10-24, 03:59 PM
