Thread: arch door?
    2008-07
    9
    Default arch door?
    I'm new to ACA, cant find where or how to insert an arch door, I saw one on the ACA help but can't find it. neither on the design menu or the design tool catalog
    is there a place to download this kind of stuff? doors, furniture etc.
    htks
    2006-12
    Big "D"
    3,711
    Default Re: arch door?
    Quote Originally Posted by ebaltierrez View Post
    htks
    Open up your tool palette (Ctrl 3). Then right click on the spine and choose either design or all (it may already open that way). You'll see a tab that says doors. Click on that. There's some doors shown there. At the bottom, there should be thing that says "more door tools". Click on that to open the design tool catalog. There should be 5 pages of doors there.
    Or if you want to make one and already have a regular door, just right click on it and choose "edit door style". When the box opens, go to the design rules tab, On the left, there it says "shape", and under that you can choose either predefined or profile. Select predefined, then on the dropdown next to it, choose arch.
    Or, you can draw a shape with a closed polyline. Then right click on it and choose "convert to profile". Once you name and save it, go to the same area above, but instead of predefined, use profile and choose the profile you want.
    There's also some content on the autodesk web site.
    http://usa.autodesk.com/adsk/servlet...linkID=9240658
    Hope that helps. If you need more help, let me know.
    2008-07
    9
    thks so much, it took me a while to comprehend the system but now its cristal clear ( I hope) thks to your help.
    thks again.
    2006-12
    Big "D"
    3,711
    That's just scratching the surface. ACA can do so much it's mind boggling. I'm sure you'll have more questions, just ask away and we'll try to help ya.
  1. 2013: Revit Arch 2013 - Door Swing Question
    By ROBP-RDS in forum Revit Architecture - Families
    Last Post: 2014-06-22, 03:22 PM
  2. 2012: RCP of linked arch model - show door swings?
    By matt__w in forum Revit MEP - General
    Last Post: 2013-04-22, 07:37 PM
  3. door family (ARCH/STRUCT problem)
    By btrusty in forum Revit Architecture - General
    Last Post: 2009-09-16, 09:24 PM
  4. arch top door
    By thomasf in forum Revit Architecture - Families
    Last Post: 2008-04-02, 01:07 AM
