Thread: What is the method to Move only a Single Shaft opening Line?
    2008-03
    43
    Default What is the method to Move only a Single Shaft opening Line?
    Hi, I have drawn a Rectangular Shaft Opening & want to Resize (Move) only one segment of it. I m using Move command to do this, but while doing this, entire Rectangular Shaft opening is moving.
    All AUGI, all the time kathy71046's Avatar
    2004-07
    Perth Australia
    736
    Default Re: What is the method to Move only a Single Shaft opening Line?
    when you select the shaft, you should get an edit button appear, click that and edit the sketch lines to change the size.
    Kathy Taylor
    Senior Structural Draftsperson & Proprietor
    TaylorCAD
    www.taylorcad.com.au
    I don't suffer from insanity - I enjoy it!
    Revit User Phase 3, 4, 5, 4, 3, 5, 4.....
    2008-05
    Brunei
    299
    Check the temporary dimension when you select one of the line. See if the dimension if its lock or not. The way you discribe the process, that element might be constrained with the connected elements.
  1. 2013: Model Horizontal Shaft - Best Method - Revit Architecture
    By Limbatus in forum Revit Architecture - General
    Last Post: 2013-02-14, 12:29 PM
  2. tag size of Shaft Opening
    By cbaze in forum Revit Architecture - General
    Last Post: 2009-07-27, 10:31 PM
  3. missing shaft opening?
    By jessica.146534 in forum Revit Architecture - General
    Last Post: 2009-04-15, 03:12 PM
  4. see shaft opening in plan
    By Bryan Thatcher in forum Revit Architecture - General
    Last Post: 2009-03-27, 08:14 PM
  5. Stair Using Shaft Opening
    By aperez.126820 in forum Revit Architecture - General
    Last Post: 2008-11-17, 10:28 PM
