I would like to know if it is possible to load the AutoCad Civil 3D Land Desktop Campanion 2009 menu LINES/CURVES into AutoCad Civil 3D 2009?
The LINES/CURVES menu in AutoCad Civil 3D 2009 works fine but I would also like to be able to use the LINES/CURVES menu that is in AutoCad Civil 3D Land Desktop Campanion 2009.
I loaded the CUI command and transferred the LINES/CURVES menu from LDD and loaded it into my C3D menu profile. The menu does load everytime I start C3D but I keep getting the following errors everytime I pick a command from the menu pulldown:
"; error: no function definition: CR_MNL
; error: no function definition: AD_MNL
Command: Unknown command "LDD". Press F1 for help."
Is it possible to write a LSP file for C3D to load the LDD menu commands I want to use, and if so, what is it and where would I need to insert the LSP file?
