Results 1 to 7 of 7
Thread: Mass Floor Schedules - Calculated Value with Floor Volume
    2005-07
    172
    Default Mass Floor Schedules - Calculated Value with Floor Volume
    I just started using 2009, and I love the Mass Floor Scheduling... just one problem.
    I want to make a calculated value for Floor-to-Floor height by using the equation:
    Floor Volume/Floor Area
    However it keeps telling me that 'Floor Volume' is not a valid schedule field. I have no problem with any of the other fields in calced values.
    Any thoughts?
    2001-12
    Irvine, CA
    7,567
    Default Re: Mass Floor Schedules - Calculated Value with Floor Volume
    Hi,
    I get the same message and I think it may be a bug. When I examine the parameter Floor Volume in the Formatting Tab I find that there is a space at the end of the parameter name that is not present for the others. When I try to create the calculated parameter and include the space at the end it still doesn't work but Revit is probably discounting it internally. I think support should take a look at this.
    You can still apply Floors by Face to get what you need in the meantime...a little more work but you get what you need for now.
    [Edit: submitted support request]
    2005-07
    172
    Thanks Steve.
    dp
    2001-12
    Irvine, CA
    7,567
    Support escalated to development...bug it is...
    2006-11
    Sydney, Australia
    119
    Quote Originally Posted by Steve_Stafford View Post
    Hi,
    Steve,
    You note that you can apply Floor by Face to get the result. I don't see how - am I missing something?
    When you apply floors by face, it creates a floor slab with a thickness nominated in the floor type. When you schedule that it gives the volume of the floor slab itself - this is no use in the calculation that dp wanted to do (me too). The "Floor Volume" scheduled in Mass Floors gives the volume of the overall space, floor to floor, not the floor thickness.
    Any ideas?
    2007-07
    London, UK
    361
    Meanwhile you can do those calculations outside revit.
    ODBC extracts mass volume and area, so you can get the FFH.
    2006-11
    Sydney, Australia
    119
    I also just discovered that this has been fixed in Revit 2010 - and the calculation works just fine (Floor Volume / Floor Area) as long as you make the units "Length".
  1. 2014: Center of Mass of Floor Slabs
    By cmbyrd414656 in forum Revit Structure - General
    Last Post: 2014-12-16, 06:57 PM
  2. mass floor material
    By wbi in forum Revit - Conceptual Design Tools
    Last Post: 2011-04-19, 02:32 PM
  3. Mass floor 2010
    By amara in forum Revit Architecture - General
    Last Post: 2009-04-26, 01:46 PM
  4. Mass parameters in mass floor schedule
    By arqt49 in forum Revit Architecture - General
    Last Post: 2009-01-20, 06:10 PM
  5. Creating floor from mass
    By Wagurto in forum Revit Architecture - General
    Last Post: 2004-12-14, 01:47 PM
