Thread: Change Paperspace Background Color with .NET
    2008-09
    Default Change Paperspace Background Color with .NET
    I try to migrate the following VBA program to .NET but witout success.
    Could help me?
    Public Sub DEU_MDCNE_SwapLayoutBackgrnd()
        'Initialize
        Dim preferences As AcadPreferences
        Dim currGraphicsWinLayoutBackgrndColor As OLE_COLOR
        Dim StdGrey As OLE_COLOR
        On Error GoTo Error
        Set preferences = ThisDrawing.Application.preferences
        StdGrey = 12632256
        ' Retrieve the current GraphicsWinLayoutBackgrndColor value
        currGraphicsWinLayoutBackgrndColor = preferences.Display.GraphicsWinLayoutBackgrndColor
        ' Change the value for GraphicsWinLayoutBackgrndColor
        If currGraphicsWinLayoutBackgrndColor <> vbWhite Then
            preferences.Display.GraphicsWinLayoutBackgrndColor = vbWhite
            Else: preferences.Display.GraphicsWinLayoutBackgrndColor = StdGrey
        End If
        Exit Sub
    Error:
        MsgBox "Error " & Err.Number & " (" & Err.Description & ") in procedure 'DEU_MDCNE_SwapLayoutBackgrnd'"
    End Sub
    Last edited by Opie; 2008-09-16 at 04:31 PM. Reason: [CODE] tags added, see Moderator Note
    Member dmarcotte4's Avatar
    2003-10
    43
    Default Re: Change Paperspace Background Color with .NET
    Here is a sample in C#
    Daniel
    using Autodesk.AutoCAD.EditorInput;
    using Autodesk.AutoCAD.Runtime;
    // A reference to COM
    using Autodesk.AutoCAD.Interop;
    using AcAp = Autodesk.AutoCAD.ApplicationServices;
    [assembly: CommandClass(typeof(ExecMethod.Commands))]
    namespace ExecMethod
      public class Commands
        [CommandMethod("doit")]
        public static void PaneButton()
          Editor ed = AcAp.Application.DocumentManager.MdiActiveDocument.Editor;
          try
            AcadPreferences pref = AcAp.Application.Preferences as AcadPreferences;
            pref.Display.GraphicsWinLayoutBackgrndColor = 12632256;
          catch (System.Exception ex)
            ed.WriteMessage(ex.Message);
  1. 2011 paperspace background color
    By Spectrefish in forum AutoCAD LT - General
    Last Post: 2013-03-14, 03:43 PM
  2. Change Background Color for outside layout
    By Capt. Computer Crasher in forum AutoCAD General
    Last Post: 2009-11-17, 08:48 PM
  3. Change Background color of Cells
    By Jack Cheong in forum AutoCAD Tables
    Last Post: 2008-05-22, 11:33 AM
  4. Why would MS background change color?
    By kleenhippie in forum CAD Management - General
    Last Post: 2008-01-25, 02:06 PM
  5. Change Field background color
    By ccowgill in forum AutoCAD Fields
    Last Post: 2006-02-09, 12:09 PM
