I have a project that is shifting from a single permit package to a Core & Shell and TI approach at effectively 50% CDs for the Core & Shell. Currently everything is modeled on the New Construction phase, whereas about 70-80% of what is currently modeled should be C&S, while the rest will be TI. Ideally I would like to convert to the new phases with the manual changes being made to the TI stuff as there is less of it. To that end, I combined New Construction with Existing, Renamed Existing to C&S, then created a new TI phase that follows. Now I can simply move the TI stuff "forward. All should be fine, except that the rooms are all on C&S phase, so when I change a wall to TI any rooms it defines blow up. And all the rooms seemingly can't be changed to the TI phase where they really belong. I really hope I don't have to delete all the rooms and replace them in a TI view, but that is all I can come up with. And to make matters worse, in a TI view, even set to Show Complete, I get no rooms, so we would need to set the view to C&S, delete all the rooms, set the view to TI and place all the rooms again. I am not even sure that will work as when placing a room (that was deleted from the C&S view) while in a TI view I only get New as an option, the deleted rooms are not available. But switch back to a C&S phase and my deleted rooms are available to place. This is a 360,000 SF campus in 8 buildings, 3-5 floors per building, and as many as 50+ rooms per floor in some places, with a ton of LEED, program and finish data in those rooms. In other words, a HUGE amount of work to start over from scratch.
So, is it really not possible to change a rooms phase? Am I stuck putting everything on TI and moving 70-80% of the modeled items into C&S just because the rooms can't be moved? And is it just me or does this feel like a bug and we should be able to change room phase just like any other object? Or perhaps I can and I just don't know how? Sure hope that is the case.
Gordon
