Thread: HELP! ! ! W/ Lookup Table
    All AUGI, all the time TerribleTim's Avatar
    2006-03
    Tacoma, Wa
    643
    Default HELP! ! ! W/ Lookup Table
    Ok gang, here's a Good one for you. I decided to dig into lookups today only to find that all the info I see shows this handy Little "Lookup Table" that should open up when you place the lookup action. Only the table does not show up! Everything goes unselectable, like when your layer manager is off screen somewhere, and I can't click on anything! If I hit enter it brings up the "Add Parameter Properties" dialog box. Any advice? How can I get my Lookup Table box back?
    2006-03
    Tacoma, Wa
    643
    Default Re: HELP! ! ! W/ Lookup Table
    Never mind. I got it. I'll leave this hear for others who have the same issue. The fix was "Alt+Space bar" after executing the command, then choose "move to other monitor".
    All is good in da hood!
    Now I gotta figure out these lookup thingys!
  1. 2013: Family using Lookup Table -
    By alaughlin756641 in forum Revit MEP - Families
    Last Post: 2013-06-27, 07:48 PM
  2. 2012: Lookup Table Question
    By Dr._House in forum Revit MEP - General
    Last Post: 2013-01-08, 06:01 PM
  3. 2012: MEP Lookup Table - What am i doing wrong...
    By hmunsell in forum Revit - Platform
    Last Post: 2011-09-30, 07:19 PM
  4. Help! Lookup Table Possible?
    By mark.mcmullan in forum Revit MEP - Families
    Last Post: 2009-12-02, 05:27 PM
  5. Can someone supply me with an example of a lookup table?
    By robert.1.hall72202 in forum Dynamic Blocks - Technical
    Last Post: 2006-02-20, 06:11 PM
