Thread: Adding A landing to a Stair
    2005-07
    49
    Default Adding A landing to a Stair
    I have a stair I would like to add a landing to the end of it. What I did was added a boundary to extend 5' on each side of the stair and a riser to close it. The problem is the stringer is slopping. Can this be done this way or do I need to add a separate floor slab and a profile for the stringer? If at all possible I would like to do this in the stair .
    Thank you
    Richard E Lopez
    All AUGI, all the time davidcobi's Avatar
    2005-03
    Greater Los Angeles
    546
    Default Re: Adding A landing to a Stair
    When you are in sketch mode split the green boundary line at the last step/landing, select the new lines and change the slope from autodetect to flat.
    2005-07
    49
    Perfect thank you
  1. 2013: Adding a landing at the base of a stair.
    By theoryshaw in forum Revit Architecture - General
    Last Post: 2015-04-21, 10:16 AM
  2. 2015: Stair railings get screwed up at landing when adding lower extension
    Last Post: 2014-12-03, 07:57 PM
  3. 2013 - Stair Run / Stair Landing Joins
    By saeborne in forum Revit Architecture - General
    Last Post: 2012-10-04, 03:05 PM
  4. Stair landing problem
    By Tom Weir in forum Revit Architecture - General
    Last Post: 2011-11-29, 03:26 PM
  5. Stair mid-landing height
    By Adam Mac in forum Revit Architecture - General
    Last Post: 2005-06-16, 10:51 PM
