jkady
Hello all,
I have been struggling with this problem all morning, and after searching the forums I have not found an answer.
My problem is simple: I want my structural column cut pattern to show up on all plan views, in all phases. The columns are existing, and the cut pattern shows up in phase existing. When I move to the demolition and new construction views, the columns show up without any pattern.
I just completed another project in Revit 2008 that had the same situation (same client for both projects). And it worked as it should. This project is in Revit 2009, so at first I thought that might be the reason for my troubles. I upgraded my earlier project to 2009, transferred project standards in the hopes of fixing this. It didn't work.
As far as I can tell, all of the visibility settings are the same for both projects. The columns I am using are the exact same family for both projects. I have looked in graphic overrides, in materials settings, view propoerties, etc. I have gone into the family and looked at parametric settings... I can't find that one piece of information that I know I am missing!
I have attached two images - the existing & new construction plans so you can see what I am talking about.
I really hope someone here can shed some light on this for me! Thank you!!
