Thread: ADT 2005 & Menuload
    2003-09
    9
    Default ADT 2005 & Menuload
    We have one custom partial menu we have used with AutoCAD2000i and earlier releases. We wish to continue using this menu in ADT2005.
    While we able to load it and operate it under ADT2005, it will not stay loaded between sessions. When you exit and then restart ADT2005, this partilal menu disappears and has to be loaded again with menuload.
    We have put the partial menu in its own directory on D: and added that to the autocad support files search path. This didn't help.
    Has anyone experienced a similar problem and fixed it?
    (We are running ADT2005 under Windows XP Professional with Novel Networking.)
    2001-03
    13,499
    Default Re: ADT 2005 & Menuload
    Hi
    Have a browse of the following thread -
    menu item won't stick
    Have a good one, Mike
    2003-09
    9
    Mike,
    The gist of that thread was that your menu won't reload if the menugroup name has a space in it. Ours doesn't. It is simply RP. Here is the menugroup line:
    ***MENUGROUP=RP
    We have another idea to try from another similar thread and will try removing all blank lines from the menu file as well.
    Thanks. Additional comments and suggestions are still welcome.
    Ron Harris
    2003-09
    9
    Problem has been solved!
    The menu files and associated lisp files were all read only in a read only directory on the network. After changing them to read-write, the problem went away.
    We had tried copying all the menu files to a local drive to deal with the problem but it is probable the read only attributes were copied with them.
    We suppose that there was a compiled version of the menu from 2000i that couldn't be overwritten or used by ADT 2005.
    Ron
  1. add CUI without menuload
    By chris.goonan in forum ACA General
    Last Post: 2008-03-15, 05:28 PM
  2. menuload and cuiload
    By reinaldo.sampaio in forum Português - Customização / Programação
    Last Post: 2007-07-30, 06:49 AM
  3. Replies: 3
    Last Post: 2006-02-01, 05:13 PM
  4. LDT Menuload Fail
    By justin.d.ehart in forum Land Desktop - General
    Last Post: 2004-11-19, 05:10 PM
  5. AutoCAD 2005 Menuload
    By frogge in forum AutoCAD General
    Last Post: 2004-07-15, 05:23 PM
