Results 1 to 6 of 6
Thread: Void Form for Coffered Ceiling/Slabs
    100 Club r.grandmaison's Avatar
    2003-11
    location location
    192
    Default Void Form for Coffered Ceiling/Slabs
    I've built a coffered shape to create a coffered (i.e. two-way waffle) ceiling/slab system It works fine as a Sweep Void component- however, I'm having one minor issue with it.
    When I bring the component into a model that has a 12" thick slab, it voids out the slab properly- until I change the slab/floor thickness. When I do that the void simply will NOT travel down to the bottom of the slab. I've aligned the bottom of the void to the bottom of the Floor1 in the FloorHosted family- am I missing something here? Is there some other way I should tell the Void to always connect to the bottom of the floor/slab?
    Thanks, I'm new to this and appreciate the help and everyone's experience.
    AUGI Addict Andre Carvalho's Avatar
    2006-06
    Toronto, ON
    2,386
    Default Re: Void Form for Coffered Ceiling/Slabs
    And you have aligned AND locked, isn't it?
    2003-11
    location location
    192
    Quote Originally Posted by Andre Carvalho View Post
    Yes, I aligned it with the Align tool to the bottom of the Floor1 in the family editor and locked it.
    Works GREAT so long as the floor is also 12" deep in the project, but if I adjust the floor depth via Element Properites, or use a different thickness to a new floor, the Void Components come in at the 12" depth from the original Floor1 in the family.
    2006-06
    Toronto, ON
    2,386
    Quote Originally Posted by r.grandmaison View Post
    When editing your family, go to an elevation view, so you can see the bottom of the floor. Create a reference plane anywhere below the floor, align and lock it to the bottom of the floor. Select the reference plane and go to its properties. Give a name to it. When creating the void, use the named reference plane as work plane to host the void. Any dimensions to the void should be taken from this reference plane as well.
    Doing this should make your void follow the bottom of the floor, even if it change thickness in the project.
    Andre Carvalho
    2003-11
    location location
    192
    When editing your family...
    Andre Carvalho
    It did! Thanks so much Andre.
    Now, is there any way to get the floor volume to recognize the fact that a void has removed some of it's volume? It doesn't appear that the coffer voids actually remove any volume from the slabs.
    Revit Technical Specialist - Autodesk Scott Davis's Avatar
    2003-04
    Chino, CA
    4,743
    see Steve Stafford's blog on this subject: www.revitoped.com
    He confirms the volume does not get subtracted from the floor, unless the void cuts both top and bottim surfaces of the floor.
    Scott D Davis
    AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
  1. Coffered ceiling and Trim profile sweeps. How to?
    By csteinke.design220819 in forum Revit - Conceptual Design Tools
    Last Post: 2012-03-05, 01:34 PM
  2. Coffered Ceiling Block
    By clshade in forum Dynamic Blocks - Sharing
    Last Post: 2011-09-09, 12:11 PM
  3. generic model , void form, void extrusion
    By ntnik in forum Revit Architecture - General
    Last Post: 2009-01-29, 12:59 PM
  4. Parametric Coffered Ceiling Tutorial
    By tomislav.zigo in forum ACA/AMEP Tips & Tricks
    Last Post: 2007-02-28, 05:00 AM
  5. Cut Geometry, Solid form, Void form
    By mmolina in forum Revit Architecture - General
    Last Post: 2005-05-11, 09:33 PM
