Results 1 to 10 of 12
Thread: Network License manager problems
    2005-12
    Hartford, CT
    394
    Default Network License manager problems
    This morning several people were un-able to obtain a network licence of Acad or Revit (we are on Revit Series). I went to the license server and performed a status inquiry. It showed that I had several licenses checked out at the same time but I did not have the software open. I went my station to see if I had borrowed a license and not returned is (I have a laptop). I opened both ACAD and Revit and did not have any borrowed licenses. So whats the deal? Below is a part of the status report. What does the 'Linger 289620' mean?
    JeffW Jeff-W_LT Jeff-W_LT (v1.000) (tecton-xcopy/27000 101), start Mon 9/15 10:12 (linger: 896040)
    Tim Tim_M-lt Tim_M-lt (v1.000) (tecton-xcopy/27000 301), start Mon 9/15 10:12 (linger: 289620)
    Tim Tim_M-lt Tim_M-lt (v1.000) (tecton-xcopy/27000 201), start Mon 9/15 10:12 (linger:
    2000-01
    Seattle WA USA
    5,859
    Default Re: Network License manager problems
    Linger is a borrowed license. I've seen this happen on occasion. It is possible to return the borrowed licenses from the client machine.
    You need to copy the LMUtil.exe from the license server to your client computer.
    Open a DOS command prompt to the .exe location.
    C:\Temp> lmutil lmborrow -status
    This lists the borrowed licenses. Note the feature name(s).
    Return the license to the server with the following, where <server> is replaced by your actual server name and <feature name> is replaced by the feature name you noted above. This also assumes that the license server's port is the default 27000.
    C:\Temp> lmutil lmborrow -return -c 27000@<server> <feature name>
    If the command is successful, all you get at the command prompt is:
    lmutil - Copyright (c) ... <blah, blah, blah>
    R. Robert Bell
    Design Technology Manager
    Stantec
    2005-12
    Hartford, CT
    394
    I ran that utility with no luck. I tried that command string with every feature name in the license file and every time I got back a message saying 'no licenses borrowed' or something along those lines
    2000-01
    Seattle WA USA
    5,859
    You cannot use the feature name in the license file. Use the feature name as found on the client station. You should be running all this on the client, not the server.
    R. Robert Bell
    Stantec
    2005-12
    Hartford, CT
    394
    Quote Originally Posted by RobertB View Post
    I am running this on the clinet station. I guess I am confissed about the feature name. What I did was look at the license file for the feature names (ex 54700REVITS_2008_of) and typed that name into the command string in the client computer.
    where can I find the feature name on the client station?
    2000-01
    Seattle WA USA
    5,859
    So you run the status query on your laptop, and it shows licenses, yet you cannot return them? According to the server, it looks like you are going to be holding those licenses for the next 3 days.
    What does the status query on the laptop return?
    R. Robert Bell
    Stantec
    2005-12
    Hartford, CT
    394
    I have only run the status inquiry on the server, not my laptop. How do I run it on the laptop? Do I need to install lmtools ?
    2000-01
    Seattle WA USA
    5,859
    Quote Originally Posted by tim.101799 View Post
    You can copy the executable to the laptop.
    R. Robert Bell
    Stantec
    2005-12
    Hartford, CT
    394
    Done.....when I run it and perform a status inquiry I get the same exact info as if I run a status inquiry at the server.
    2000-01
    Seattle WA USA
    5,859
    And now run the return as I detailed from the client.
    R. Robert Bell
    Stantec
  1. Replies: 0
    Last Post: 2012-02-27, 06:18 PM
  2. Revit 2010 Network License Manager
    By jcoe in forum Revit Architecture - General
    Last Post: 2010-04-27, 11:37 PM
  3. Network License Manager
    By khalidisi in forum Networks
    Last Post: 2007-12-03, 03:33 PM
  4. Network License Manager
    By rafterman in forum Revit Architecture - General
    Last Post: 2006-06-29, 12:41 AM
  5. License Manager problems
    By jarkko.rauvanlahti in forum Revit Architecture - General
    Last Post: 2005-10-19, 12:34 AM
