Thread: OLE Object tracing
    Question OLE Object tracing
    I recently upgraded to LT 2004 and I am very disappointed with the way they seem to have changed the way OLE objects display. In previous versions I have become accustomed to scanning a designers graphics into a JPG file, importing it as an OLE object, locking the OLE layer and then tracing the object on another layer. This is a quick and easy solution to getting designers "napkin drawings" into AutoCAD format.
    LT 2004 does not seem to display OLE objects only a white square with the title of the object. Am I doing something wrong? Is there a solution to my problem?
    13,656
    Default Re: OLE Object tracing
    Hi
    Take a look at the system variable OLEHIDE.
    Have a good one, Mike
  1. Tracing DWG in Revit
    By Existing Conditions in forum Revit MEP - General
    Last Post: 2011-01-20, 05:35 PM
  2. Insert PDF for tracing
    By dzatto in forum Revit Architecture - General
    Last Post: 2010-03-05, 07:18 PM
  3. Importing and tracing a 3D dxf
    By ck.107547 in forum Revit Structure - General
    Last Post: 2007-05-08, 03:48 PM
  4. Easier tracing over DWG's
    By JamesVan in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-02-09, 04:44 PM
