Thread: Ductile Iron Pipe Fittings
    2008-09
    2
    Question Ductile Iron Pipe Fittings
    Does anyone know where I can find large diameter (6"-24") ductile iron pipe (DIP) fittings and valves for use in Revit MEP 2009?
    Thanks for your help!
    2006-12
    33
    Default Re: Ductile Iron Pipe Fittings
    Seems no material specified fitting and valves in RMEP.You could specify pipe as ductile iron pipe first then could get the size range you want. As fitting and valves, maybe some flanged could be used for DIP.
    Hope this helps.
  1. Replies: 2
    Last Post: 2015-08-23, 12:25 AM
  2. Replies: 0
    Last Post: 2012-06-28, 03:49 PM
  3. 2012: Where are ductile iron flanged fittings?
    By GreyHippo in forum Revit MEP - General
    Last Post: 2011-12-09, 09:01 PM
  4. dutile iron pipe question
    By cwest.208336 in forum AMEP General
    Last Post: 2009-04-29, 06:07 PM
  5. Ductile Iron Flanged Wierdness
    By Paul.Hellawell in forum Revit MEP - General
    Last Post: 2007-11-13, 09:54 PM
