Results 1 to 10 of 13
Thread: Adjustable swing door
    All AUGI, all the time christo4robin's Avatar
    2003-05
    Boulder, Colorado
    681
    Default
    Anybody have one that works for 90d and other angles?
    The ones on Rugi fall apart when I adjust the swing to 90d and then flex the width.
    In general, what is the best way to have a parametric angle in a family, and be able to move that angle's vertex with other geometry?
    Christopher Herr
    Studio H:T
    Republic of Boulder
    2003-05
    5,153
    Default Re: Adjustable swing door
    Here you go.
    These are from Mr. Z originally I think.
    I also have double door and bifold if you want them, let me know.
    If you have a close look at the families, you will see how the parametric angle works.
    Bruce Gow.
    Karel*CAD. Application Specialist..
    Architect.
    Revitalize. Blog
    Member maxxue's Avatar
    2003-06
    TAIWAN
    10
    Quote Originally Posted by beegee
    Here you go.
    good but angle can't be zero!
    the same i did
    All AUGI, all the time mlgatzke's Avatar
    2003-05
    Ankeny, Iowa, USA
    761
    No, the angle cannot be zero (0). However, it can be set to anything else though. Revit seems to not like any angle being set to zero, not just door opening swings.
    2003-06
    TAIWAN
    10
    Quote Originally Posted by mlgatzke
    i know why it can't be zero,through i try for hours
    it can be zero if plan has no symble line for swing,
    if you have to draw the swing line , don't lock it at door panel end
    2003-05
    Ankeny, Iowa, USA
    761
    Makes sense. The line would be too short (zero length). Boy, do I feel stupid. Thanks for the wake-up call.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,439
    I have started to assemble doors out of nested pieces, this makes this much easier, I've made typical door panels, ie glass panel, flush, etc. then I load those into a new door family with just the frame in it. then you can place a dimension setting the angle of the panel and not worry about it aligning with symbol lines etc.
    Scott D. Brown, AIA
    Project Coordinator | Director of Building Information Modeling
    HHCP.com
    Revit Technical Specialist - Autodesk Scott Davis's Avatar
    2003-04
    Chino, CA
    4,743
    It cannot be zero, but it can be .1, which is small enough that no one would notice.
    Scott D Davis
    AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
    2003-06
    TAIWAN
    10
    sorry! i make you angry....,ofcause the swing line can't be shorten to zero any way,
    my case has no swing line,so.....
    i insert it to project, and set angle parameter to zero, it work correct
    ...just study case.....
    Active Member gnl's Avatar
    2003-05
    rome (italia)
    94
    The way I did it in order to be able to use the 0 and 90 degrees values was to create a new parameter with a value of 0.00001 or something like that.
    then I set the opening parameter (angle) to be a function of that new parameter so even If I put 0 or 90 as a value for the opening angle, it will be always something a little more than that value, but so small that it's impossible to see the difference...
    ciao
  1. Adjustable Door Swing.. just one problem
    By rtaube in forum Revit Architecture - Families
    Last Post: 2010-06-11, 04:26 PM
  2. Door family w/ curved swing new and straight swing existing
    By ericsson in forum Revit Architecture - General
    Last Post: 2007-12-19, 03:02 PM
  3. Adjustable swing door family
    By Henry D in forum Revit Architecture - Families
    Last Post: 2005-08-11, 05:12 PM
  4. Attaching a door plan swing to the door leaf?
    By patricks in forum Revit Architecture - Families
    Last Post: 2005-03-24, 06:56 PM
  5. Help, Does anybody had an adjustable swing double "glass' door.
    By cosmickingpin in forum Revit Architecture - Families
    Last Post: 2005-03-22, 12:52 PM
