Results 1 to 6 of 6
Thread: Remove / Delete Device Style
    2007-08
    St. Louis
    51
    Default Remove / Delete Device Style
    Is it possible to remove a device style from a drawing?
    2003-10
    San Francisco CA
    1,190
    Default Re: Remove / Delete Device Style
    Quote Originally Posted by seanjames View Post
    Hi Sean,
    If it's not being used in the drawing, sure.
    You can either go to FILE - Drawing Utilities - Purge Building Systems Objects to delete all unused styles or go to FORMAT - Style Manager - Electrical Objects - Device Styles and right click and select purge to only delete unused devices.
    Hope this helps,
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
    2007-08
    St. Louis
    51
    Quote Originally Posted by stelthorst View Post
    Hi Sean,
    Hope this helps,
    Scott thanks for the reply.
    My problem lies in that I want to delete one or some that I guess ARE used. For example I started with copying the lighting drawing (Lighting - Fluorescent (US Imperial).dwg) and renamed it then I modified some of the "Device Styles" to meet our company standards. Now I want to thin out the device styles to only include ones that I modified.
    I tried to purge both ways that you described but it won't purge any that I select.
    Thoughts anyone?
    2000-01
    Seattle WA USA
    5,859
    Now I want to thin out the device styles to only include ones that I modified. ... Thoughts anyone?
    Sure. Open a new drawing in addition to the original drawing. Open Style Manager and drag and drop the desired styles into the new drawing. Save the new drawing and use it instead of the old one.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2007-08
    St. Louis
    51
    Quote Originally Posted by RobertB View Post
    Thanks Robert.
    Will I need to copy anything else under the Electrical Objects besides the device styles?
    2000-01
    Seattle WA USA
    5,859
    No. That OOTB file simply provides the content for the lighting fixtures palettes.
    FWIW, I advise always placing your customized content in separate files from the OOTB files. This makes it easy to handle upgrades in the future (you don't need to worry about overwriting your own content with new OOTB files). You can use SM to easily copy any of the OOTB items into a new file, so it is not like you are making more work for yourself.
    R. Robert Bell
    Stantec
  1. Remove / Delete Block from multiple Layouts at the same time
    By autocad.13572 in forum AutoCAD General
    Last Post: 2017-08-09, 01:58 PM
  2. Delete or Remove Imported Objects.
    By autocad.wishlist1734 in forum Revit MEP - Wish List
    Last Post: 2017-05-19, 04:57 AM
  3. Delete / Remove all frozen and_or turned off layers?
    By stephen.coff in forum AutoLISP
    Last Post: 2016-10-14, 12:43 PM
  4. Unable to remove plotters from Plot Device listings
    By support.70467 in forum AutoCAD Plotting
    Last Post: 2004-06-23, 06:26 AM
  5. Unable to remove plotters from Plot Device listings
    By support.70467 in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-06-22, 08:30 PM
