Hi,
I'm using Revit 2009. I imported 3D CAD models ( furniture) into a revit project , and then rendered an interior scene , using BEST quality and ONLY INTERIOR LIGHTS , I turned off the lights that don't affect the scene , and I chose PRINT 150 DPI , the rendering took about 40 hrs , I'm not sure if I'm doing something wrong or if there is some kind of a setting that reduces the rendering time?????
also I tried rendering the same scene and I chose "interior Artificial and sunlight " but the rendering turned out very dark , ( I turned the daylight portals on) , any ideas why it came out dark ????
does anybody know if there is a rendering engine that I can use with revit , so I can export the revit model into it and render the scene without setting up the Materials and the lights that I already set up in Revit??
thanks
