Thread: Angled parking arround a curve
    Active Member ewhite's Avatar
    2003-08
    Minnesota
    83
    Question Angled parking arround a curve
    I have this complicated parking field with all of the parking bays being based around concentric arcs. The client now wants to go with one way drive isles along the outermost arc. So this means I now need to do angled parking. The city requires 60 degree angled and 9 foot width stalls. Anyone know an easy way to do this?
    So far I have derived my 60 degree angle from a line tangential to the outermost arc and starting at the beginning point of the first stall, then offset 9 feet. Checked the distance along the arc between the two lines, then I did an array with that distance, and filled the angle I desired. The result is less than perfect, but it will do if no one has a better way.
    I'm not sure if this is the appropriate forum, but I figured there where some civil people who here who have done some interesting commercial layouts.
    Thanks!
    Eric White
    2007-08
    94
    Default Re: Angled parking arround a curve
    Land desktop has a layout tool for laying out parking stalls, and included curves. The problem is that it does not do angled parking around a curve. C3D has some parking tools in the tool palettes, but does not include parking around a curve. I think your best bet is to do what you did. Draw a couple of lines close to where they need to be and then do a polar array to lay out the rest.
    2006-12
    Loveland, CO
    734
    If you know the spacing along the curve, use the measure command and select a block that is made from a line rotated at the appropriate angle.
    Brian J. Hailey PE
    CAD-1
    Civil3D PLUS My blog
    At Your Desk Training
  1. 2015: work arround families 3d and 2d
    By Menno de Vries in forum Revit MEP - Families
    Last Post: 2015-01-31, 10:54 PM
  2. Replies: 1
    Last Post: 2014-04-21, 10:29 PM
  3. Parking schedule with square feet per parking space
    By Archman in forum Revit Architecture - General
    Last Post: 2006-11-20, 07:11 AM
  4. Parking Spaces--Parking Component or Site Componenet
    By Eric Stewart in forum Revit Architecture - Families
    Last Post: 2003-11-07, 09:32 PM
