I tried to find the answer to this one but without any luck. There is a user here that is inserting blocks from a palette, they look to be the right scale when he inserts them but after he rotates them they scale down. This only happens with some of the blocks and I have checked to make sure that the auxiliary scale is set to none as well as the scale being set to 1. These settings are actually the same as others that are inserting correctly.
Any help would be appreciated!
Thank you in advance!
