Thread: Problem with making solid
    2008-09
    78
    Default Problem with making solid
    Hello, I'm using AutoCad 2004. Briefly I've constructed a box with windows and a doorway. The windows and doorway have depth, ie a 'z' dimension. Whatever I select either the parts of an individual window or all the windows or even the whole thing. Rightclicking after selection just returns to the original state. ie, nothing joined.
    The 'union' just doesnt seem to work. I've selected all the different objects and they dont form a solid. I did a test on another drawing and it works fine. What could be different on this one? Thanks.
    0,0,0 The Origin
    8,028
    Default Re: Problem with making solid
    Hi Roger, welcome to AUGI.
    When you say "doorway" do you mean door and/or door frame?
    Are you sure that the doors/windows are solids not meshes?
    Are they in a block(s)?
    Are they on a locked layer(s)?
    What does the LIST command tell you about the objects?
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2008-09
    78
    Quote Originally Posted by jaberwok View Post
    http://i27.photobucket.com/albums/c1...r/IMG_0322.jpg
    Hello John. Glad to be here. Thanks for your help. As a novice I can do no better than put up a pic of my drawing so far (above) and a copy of the 'list' command (below) in which I selected the whole drawing. I havent included all of the results as there were three pages of it but this is a sample from the top. I'm afraid it means little to me apart from the coordinates except that I can see no mention of a 'mesh' and the layer is '0' throughout. Thanks
    Select objects: Specify opposite corner: 57 found
    Select objects:
    BODY Layer: "0"
    Space: Model space
    Handle = B7
    Bounding Box: Lower Bound X = 85.0000 , Y = 50.0000 , Z = -5.0000
    Upper Bound X = 90.0000 , Y = 58.6603 , Z = 0.0000
    REGION Layer: "0"
    Space: Model space
    Handle = B6
    Area: 261.4185
    Perimeter: 70.9440
    Bounding Box: Lower Bound X = 80.0000 , Y = 30.0000 , Z = 0.0000
    REGION Layer: "0"
    Space: Model space
    Handle = B5
    Area: 100.0000
    Perimeter: 50.0000
    Bounding Box: Lower Bound X = 90.0000 , Y = 30.0000 , Z = -5.0000
    Upper Bound X = 90.0000 , Y = 50.0000 , Z = -5.0000
    0,0,0 The Origin
    8,028
    If these were solids it looks as if they have been exploded.
    Regions can be Extruded but I don't think you can do much with bodies.
    Try "Historymode" and "Historyshow" - I think they were introduced in A2007 so will be "unknown command"s for you but, if they are recognised by your software, you may be able to backtrack to before the Explode operation.
    John B
    2008-09
    78
    Cheers John
  1. asd 2012 3d solid using problem
    By alikolbakir540322 in forum AutoCAD Structural Detailing
    Last Post: 2012-03-02, 09:01 AM
  2. Replies: 17
    Last Post: 2008-05-02, 04:56 PM
  3. Making a pdf file- creating problem
    By sudhirkizhakoote in forum Software
    Last Post: 2005-12-04, 07:29 PM
  4. Revolved Solid Model Problem
    By mark.okikawa in forum Revit Architecture - General
    Last Post: 2004-06-08, 09:26 PM
  5. Making new textures...problem
    By Kroke in forum Revit Architecture - General
    Last Post: 2003-05-15, 02:04 AM
