Thread: Warning: Could not create geometry for Space.
    2007-06
    34
    Default Warning: Could not create geometry for Space.
    I have two spaces on a particular floor that won't let me adjust the upper limit to the next floor (ie I want to go from Level 0 to Level 1). The warning "Could not create geometry for Space" shows up and my space can't be created. The warning occurs when I set the Upper Limit to Level 0 and adjust my Limit Offset to the slab above and also when I set the Upper Limit to Level 1 with the Limit Offset at 0' 0". I am able to create and maintain a space only when it is below a certain height. All other spaces on the floor are set for Upper Limit = Level 1 with no offsets and they work as intended. I am thinking it has something to do with the architectural model in that location, but am not sure. Has anyone else run into this problem?
    2003-04
    Irvine, CA
    6,770
    Default Re: Warning: Could not create geometry for Space.
    I'd suspect that there are no bounding elements above a certain point and the "area/volume" floods out into other areas.
    2007-06
    34
    I was thinking along those lines as well, but on the floor below, there is a wall floating in mid-air and the bounding elements work (see attached). I am trying to do a rough load calc and don't want the area to be counted as exterior space. I have the sliver space set to 1', so it might not matter. To ultimately fix the problem, do I just have to play in the Arch model until it works or is there a way to force the space to do what I want?
  1. Create Balloon that's not attached to geometry?
    By gerrard.hickson in forum Inventor - General
    Last Post: 2010-10-06, 03:18 AM
  2. Using Excel to create + control Revit Arch geometry?
    By nmiller.220753 in forum Revit Architecture - General
    Last Post: 2009-12-17, 10:17 AM
  3. Question on Lisp, trying to create a Warning Box.
    By Dr._House in forum AutoLISP
    Last Post: 2009-09-17, 08:25 PM
  4. How to create a space in a model with open geometry
    By sgermano in forum Revit MEP - General
    Last Post: 2008-12-15, 08:16 PM
  5. Warning - Can't Create?
    By cadman6735 in forum Revit Architecture - General
    Last Post: 2008-10-21, 09:42 PM
