Thread: Custom Sizes for Fan Powered VAV
    2007-12
    Toronto, ON
    29
    Default Custom Sizes for Fan Powered VAV
    By default, the Series Fan Powered VAV Boxes do not have the outlet sizes I need. What do you usually do to get the right sizes from the VAV Boxes? I'm trying not to do the Parametric Part Wizard since I want to show more details than just the box.
    This is what I tried but didn't work: wblock the part into a new block, then BEDIT(to modify the properties of the block, then make Block-based part out of it) but when I'm in BEDIT I can't explode the block to change the outlet size. Tried the same thing in model space and still didn't work. What do I need to do to get it working?
    Any help is appreciated and thanks.
    -John
    2007-12
    Toronto, ON
    29
    Default Re: Custom Sizes for Fan Powered VAV
    and btw, is there a way to get AUGI Forums to send me an email whenever someone replies? Thanks.
    All AUGI, all the time buzz's Avatar
    2007-10
    Tucson, Arizona
    613
    John,
    You will need to edit the Parametric Part with the Content Editor (CAD Manager > Content Editing > Content Builder). This can be a pain, so make a backup copy and remove sharp objects from your desk.
    You may also want to look at using mvparts instead.
    Here are some links that may help you out:
    http://geniusoft.blogspot.com/2008/0...ric-parts.html
    http://geniusoft.blogspot.com/2008/0...-takeoffs.html
    http://www.geniusoftllc.com/mvparts/create.asp
    -Buzz
    no trophy, no flowers, no flashbulbs, no line,
    he's haunted by something he cannot define...
    humble genius
    2006-11
    Waukesha, WI
    87
    In the "control panel" of your augi account you can change all the settings including email notifications time zone personal info and pictures.
  1. Custom page sizes are greyed out
    By jasontirone in forum AutoCAD Plotting
    Last Post: 2011-06-10, 07:17 PM
  2. Custom Plot Sizes
    By tra1133 in forum AutoCAD Plotting
    Last Post: 2009-10-13, 04:06 PM
  3. Custom Sheet Sizes
    By s_morgan_b in forum AutoCAD Customization
    Last Post: 2009-01-14, 11:42 AM
  4. Custom Sheet Sizes
    By KansasCAD in forum AutoCAD Plotting
    Last Post: 2006-02-13, 08:50 PM
  5. Custom Paper Sizes
    By RobertW.82344 in forum AutoCAD Plotting
    Last Post: 2005-03-25, 12:32 AM
