We have a building which is curved in plan--a simple arc-shaped footprint.
Column grids are placed parallel to the radius of the curve, and also in a radial pattern from the centerpoint of the arc which defines the curve, at 13' on center.
The grids all show up in 1st floor plan--both curved and radial.
However, after trying to propogate extents, none of the grids show in exterior elevations.
We have checked to make sure they are set to 3D extents, and they are not associated to any scope boxes.
We suspect this is because the building is curved, and that the elevation tags are not
perpendicular to the view, so the grids do not show in elevation?
If this is true--can anyone confirm, and better yet have a solution?
Any help appreciated .........
