Results 1 to 10 of 18
Thread: Our 'Where do we go from here with Revit?' meeting
    2003-12
    3
    Default Our 'Where do we go from here with Revit?' meeting
    We are a 13-person firm that's used Revit for 4 years. It hasn't been an unmixed blessing. Here are minutes from a recent meeting on 'Where do we go from here?'
    Crossroads Meeting
    Present: Chris, Jonathan, Carol, Peter, Tarik, Pooja, Chuck
    Date: September 28, 2004
    1. Situation: We’ve been at Revit for several years. It has failed to take over of its own accord. Revit jobs seem to take longer than Acad jobs. We’re just finishing Hamilton Dorm, a big, complex, worksetted renovation project without enthusiasm.
    2. Options: We developed the following list of options:
    A – Keep at it. Manage training & production aggressively. Make it work.
    B – Use Revit just as a design tool. Acad for production.
    C – Use Revit or Acad depending on what you’re comfortable with.
    D – Use Revit for production only if no worksets
    E – Use Acad 3D models and 3D Studio Max.
    F – Use Revit as a design tool, then keep the floor plan only in production.
    G – Use Revit modeling back and forth with hand drawing as a design process.
    3. The Voting:
    a. Carol: I’ve forgotten AutoCAD. I’ve been working with John, a principal who requires good linework, so I’ve been using Revit linework successfully.
    Can’t do B., because of having forgotten acad.
    I don’t like worksets.
    If you’re the only person, Revit is powerful and great.
    Floor plans are much faster in Revit than AutoCAD. For many projects, a floor plan is all you have to do.
    The strength is in floor plans and scheduling.
    Don’t obsess about the model; do wall sweeps or other fussy things. Do what feels natural in linework. Drafting views are great.
    Do an office standard. i.e.:
    - Floor plans: Revit
    - Schedules: Revit
    - Elevations: Acad
    - etc.
    - etc.
    I vote for D.
    b. Peter: (Peter and George just finished up the Hamilton project).
    We had a substantial fee on Hamilton, and still managed exceed our budget. I know we could have done Hamilton in far less time in AutoCAD.
    If you could just sit down and get things done it would be fine, but you run into glitches, and resolving the glitches takes forever.
    I’m very frustrated by worksets. George tends to grab all the worksets, so I have to spend time getting him to release what I want to work on.
    The software should be a conduit for communication between co-workers on workset access.
    The system is incredibly prone to human error. There is a chronic problem with putting things on the wrong workset. The software should manage this.
    We had a terrible time with Hamilton controlling wall cleanup. I’d work for hours and finally get something looking presentable, then go home, and by the next morning it’s all screwed up again. This happened over and over again. Sometimes it happens when you’re working somewhere, and you try to do something and it says ‘Can’t keep walls and floor joined’ or something like that. So you say OK, and somewhere else where you’re not looking some wall join gets fouled up.
    We created too many worksets on Hamilton – too much administration of this long list.
    In spite of all this, I’m being gradually won over. There is a beauty in scheduling, once you understand how it works.
    On the Northampton Coop job, we built a family for the eave brackets and it behaved unpredictably in the model. The bracket attached itself somewhere in the inside of the wall, and the geometry of the bracket in the model wasn’t the same as the bracket in the family editor. We spent hours trying to figure this thing out.
    I vote for a mixture of B & C.
    c. Tarik: I’ve given up on Revit and have largely gone back to AutoCAD. For now, I’m trying to be as productive as I can.
    We shouldn’t forget that AutoCAD has been around for 20 years and Revit’s a very young program – only a few years old. He is hearing more about it from friends in other offices, where people are ‘experimenting’ with Revit.
    I’ve never ‘flown’ on Revit. There’s always a hangup of some sort.
    Revit’s selling point is coordination, but for most jobs most of the time, keeping things coordinated is no big deal. Revit saves time in some areas but you lose the savings in glitches.
    Revit’s scheduling is good. Managing schedules in acad is tedious.
    We need to move to current AutoCAD. Nobody, including our consultants, uses 14 any more.
    I vote for E. and G.
    d. George:
    One of our problems is that we don’t have standards – the partners and everybody else does things differently. We need office standards.
    I’ve totally forgotten AutoCAD; very comfortable with Revit.
    Worksets are not a disaster. The problem is that we do a workset project and then leave it and do another one a year later. We need to stay on it and get comfortable.
    With Revit, you need time to think, to plan things out. Example: Take the time to figure out the right wall types at the beginning.
    I like detail components.
    I like Revit for its coordination. Example: You put the date in once, then it’s on all the sheets.
    I vote for A, C and D.
    e. Jonathan:
    I can be efficient and productive on Revit; I just finished the Bete residence and it’s been profitable. But I did it all by myself.
    Worksets aren’t ready for prime time.
    I’ve done a lot of the Bete residence production drawings with linework. I don’t try to fine tune the model, but I keep it more or less up to date so I can use it for communication with the client for construction phase decisions.
    I use the model for plans and elevations, but the wall sections are all linework with the model turned off.
    I vote for D & G.
    f. Chuck:
    It doesn’t make sense to give up on Revit.
    I love Revit for early modeling studies. I do sketch overlays over the Revit models. The clients love to see the models spun around on the screen.
    But I switch to acad after schematics, or maybe DD.
    We should be using it this way. I suspect I will gradually stay with Revit longer, eventually I’ll get there.
    I vote for A & G, plus B.
    g. Pooja (who hasn’t worked in Revit):
    Why not model things when we need to in AutoCAD and render them in 3D Studio? This is what most offices do.
    h. Chris (moderator)
    I like Revit for schematic design/space planning. Working from a program to produce a floor plan with Revit (using room area tags) is very easy and natural.
    I will find out if there’s an architectural add-on like Arch-T for Acad 2005.
    Revit Arch. Wishlist Mgr. Wes Macaulay's Avatar
    2003-05
    Vancouver, BC CANADA
    3,348
    Default Re: Our 'Where do we go from here with Revit?' meeting
    How are the computer skills of your people? Do they troubleshoot well?
    What were the projects described here? Size / architectural style / basic organisation... that will help us understand more of the problems.
    Four years is a long time to figure out of you want to keep working on something. I CAN relate to the matter of wall joins going awry. I'm getting to the point where I would wish they could be turned off by default! Or maybe some sort of Lock Join setting where once a wall joins, it retains the join's state forevermore until you use the Wall Join tool on it.
    2003-04
    Chino, CA
    4,756
    wow! at least you are being thoughtful of the process and talking about it. Studies have shown that th biggest gain in Revit as far as productivity/profit potential is in the CD phase. If you are only doing SD and DD in Revit, then you are missing out on potentially the single biggest gain.
    If after four years, its not working the way you thought, maybe its time to bring in the experts to help you see where you could have improvements....did you know you can hire "Autodesk Consulting Services" that will send a team of Revit experts to your office to help you? It seems that you may be making some things m ore difficult than the y should be i.e. Too many worksets on a project. Has your office created standard Revit Templates that you use to start each project? If not, you must!
    If people in your office can seriously say they can do CD's faster in AutoCAD than Revit, they aren't using the tools correctly.
    AUGI Addict hand471037's Avatar
    2003-05
    Oakland, California
    1,934
    <lurkmodeoff>
    Buy & read this book before you do anything:
    Business @ the Speed of Stupid: Building Smart Companies After the Technology Shakeout
    http://www.amazon.com/exec/obidos/tg...17550?v=glance
    It's about how & why technology fails within business.
    It sounds like, to me anyways, that no technology is really going to give your office what it wants, for you're trying to solve a problem that's not rooted in technology. Going back to AutoCAD isn't going to solve that problem either, with the added pain of switching again & loosing abilities & capability.
    I'm thinking that, when you started using Revit within your office, someone just thought it was cool, got the boss to buy a copy, and swallowed the hype that Revit being 'easy' meant that you didn't have to think about how it was really going to fit into your business. It's amazing that something to integral and important to a firm is rarely given much real thought.
    Your problem is how you're approaching the tools in the first place.
    Case in point: the firm I'm at now has been using Revit for the last year, but when it started they had no training, taught themselves as they went, and took no time in thinking about how Revit was really going to work within their business. Hence now I'm cleaning up messes, showing them how to do some *very basic things* that they had no idea even existed (like being able to use Autocad details via Drafting Views), and helping them get to where they want to be. But that's only possible because I've been using Revit heavily for three years, and used to work for a reseller, and am rather familiar with how to 'roll out Revit' within a firm.
    If AutoCAD really does fit your business, then more power to you, but it sounds like half your firm doesn't understand Revit, while the other half does and has forgotten Autocad altogether- and you've even got people on the sidelines chiming in to use AutoCAD & MAX, because 'that's what all the firms do' (uh... yeah. right.). So the problem you've got isn't in Revit, it's in how your approaching the tools. So again, read this book, and then talk to your bosses, and your crew, and maybe an expert or two... then you'll really understand where you want to go, and how you can get there.
    Otherwise you're just flailing, and you'll be unhappy no matter what you do.
    just my 2 cents.
    <lurkmodebackon >
    Jeffrey McGrew
    Revit Guru gregcashen's Avatar
    2003-05
    Emeryville, CA
    1,352
    I agree with Jeffrey. This sounds like a business issue. Also, the fact that you have been working with Revit for this long and you have only posted here 2x indicates that perhaps your firm is not really using the FREE training resources out there to smooth out the bumps in the Revit learning curve. We are all here to lend a hand whenever you need us...use us!
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Which version of Revit did you use on your worksets nightmare projects? I was in a firm with 10 seats of revit and we had a very similiar experience to yours using worksets was a big loser. This was pre 6.0 however. Element borrowing has drastically improved the way you can work with revit and worksets. We were at the same crossroads, ie, only do jobs in revit that don't require worksets, problem, all jobs at somepoint benefit from multiple users. That issue is no longer now that you can "not check out entire worksets" Workflow today can be very fast if executed properly.
    Some things to consider.
    Do I really need to check out the whole workset(who else will be affected if I do)?
    If the answer is no, don't check it out, just do a crossing window around the items you need, right click and say make editable. If all team members work this way you will have very little overlap and less STC downtime releasing worksets and re checking them out.
    Keep the number of worksets to a minimum (but don't be afraid to add one whenever it will help the workflow) and try to base them on user task, ie, if someone is going to be working on the second floor today, have a workset for the second floor that, then if its not needed anymore collapse it and place the items on the appropriate workset.
    Avoid groups when working in a workset environment(they are better now, but can still cause problems)
    Try to divide up the job in a way that keeps users separate, ie one person creating the model, one setting up views of the model and sheets, one creating content(families). Remember that anyone at anytime now can add items to a workset even if they don't have that workset editable, just have the active workset set to whatever you need to add to.
    Good luck, and don't go backwards the rewards are out there if you stay the course!!!
    Scott D. Brown, AIA
    BECK
    2003-09
    Santa Barbara, Ca - San Jose, Costa Rica
    185
    Very interesting thread. Should also be posted on the ConDocs forum.
    2005-02
    10
    Cool Re: Our 'Where do we go from here with Revit?' meeting
    So what?
    WHAT is the BEST?
    ADT 2005 or Revit 7 ?
    Begin to thinking about it in Russia...I am frustrated,
    now I began to work in ADT, but great songs for Revit stops me!
    What I must do, help me please.
    2001-12
    Irvine, CA
    7,567
    Quote Originally Posted by ernestatar
    Sing with Revit of course!! (I'm biased naturally)
    2003-05
    5,153
    So what?
    Sing-a-long with me…
    "You say you want a Revit solution
    Well you know
    we all want to change the world
    We tell you that it's evolution
    Well you know
    We all want to change the world
    We say we’ve got a real solution
    Well you know
    You’d all love to see the plan
    You ask me for a contribution
    Well you know
    We're all doing what we can... "
  1. SE322-1U: Why Are You Not Having a BIM/Revit® Kick-off Meeting?
    By Autodesk University in forum Structural Design and Engineering
    Last Post: 2015-08-07, 05:37 PM
  2. SE319-2: Why Are You Not Having a BIM/Revit® Kick-off Meeting?
    Last Post: 2015-08-07, 05:36 PM
  3. S.F. Bay Area Revit User's Group Meeting - Aug. 17th - Meet the Revit Developers!
    By hand471037 in forum Revit Architecture - General
    Last Post: 2004-08-16, 04:08 PM
  4. Orlando REVIT Meeting
    By richard.binning in forum Local User Groups - General
    Last Post: 2004-08-16, 02:35 PM
  5. Replies: 0
    Last Post: 2004-08-13, 05:56 PM
