When you have a linked model that needs to be shown as 'existing' (or any other phase), the process to make it show up correctly in the view seems very cumbersome. Between the Phase Mapping options, visibility overrides, and not to mention changing the phase of the elements in the linked model... there seems to be too many options to efficiently control this procedure. The amount of combinations seem endless, and there was a lot of trial and error on my part to get the desired result. Has anyone had great success with this function, and can explain it in a simplified way. Right now, I'd be hard pressed to find a novice user that could set up a view with the correct phasing of a linked Revit model properly.
Thanks.
