Thread: Image over Topo Surface
    Default Image over Topo Surface
    We are starting to work a little more with topo surfaces in Revit now, and I have a user wondering if it is possible drape an image over a topo surface, so it conforms to the surface in Revit, like can be done in Sketch-up. I know Revit is not a rendering tool perse, but is this possible in Revit. from going thru the help file, it says an image can only be imported into a 2D View. any help on this would be appreciated. Thanks.
    2006-06
    Toronto, ON
    2,386
    Default Re: Image over Topo Surface
    Quote Originally Posted by michael91077 View Post
    ...I have a user wondering if it is possible drape an image over a topo surface, so it conforms to the surface in Revit, like can be done in Sketch-up.
    Unfortunately, no.
    Andre Carvalho
    Thats what I was thinking, but I had to double check before i gave a definitive "No" to that question. Thanks.
    I thought I had this actually figured out. We tried using a JPG of the aerial, and applying it to the surface as a material. this would have worked, but for whatever reason, the image was mirrored and rotated when applied. It looked like it would have conformed to the topo surface, if it had not been for that issue.
    I could stop if I wanted to Teresa.Martin's Avatar
    2004-11
    438
    Hi! You have to tweak it a little to get it to work. You might have to change the size and rotate the image in the material settings to get this to work. It is not easy. This would be a slam dunk in 3d Max by the way.
    2016-02
    Sydney, Australia
    512
    I've known about this cool tip for a few years using Accurender, and yes allot of tweeking is required to get the image in the correct location & orientation.
    There is no reason why this tip won't work with any render package as long as you can import a raster image as a surface pattern. Also note that you can do this method to apply an image to a background surface, which will help the Mental rays lack of funtionality in this area.
  1. Draping a Google Earth image over a Topo surface
    By tntdraftsol in forum 3ds Max - General
    Last Post: 2012-12-12, 04:42 PM
  2. Grade Points from an image file - Topo surface transparency
    By 3dway in forum Revit Architecture - General
    Last Post: 2011-06-08, 01:28 PM
  3. Topo surface - Again
    By johk in forum Revit - Platform
    Last Post: 2008-04-08, 03:32 AM
  4. Topo surface as a solid ?
    By bheng in forum Revit Architecture - General
    Last Post: 2007-02-08, 05:56 PM
  5. Apply a slope to an area in a topo surface (Incliner une zone dans une surface topo)
    By gravelin in forum Revit Architecture - Tips & Tricks
    Last Post: 2005-03-25, 01:23 PM
