Thread: (vla-load-com)
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,706
    Default (vla-load-com)
    After replacing a server I do have problems with "extended lisp".
    Here is some error messages :
    ; warning:AutoCAD type library load failed: "A problem occurred when reading a typelibrary or a DLL-file" ( language translated )
    error: no function definition: VLAX-GET-ACAD-OBJECT
    Command: (vla-load-com)
    Error: no function definition: VLA-LOAD-COM
    Initializing VBA System... VBA Not Available.
    I suppose something in the registry is pointing to the old server, but what ?
    How can I try to load manually ?
    Any hint ?
    : ) Happy Computing !
    kennet
    126
    Default Re: (vla-load-com)
    VLA-LOAD-COM?
    Loose the A, Kennet -> VL-LOAD-COM
    2002-05
    1,706
    ..aagh Stig, that was just a misspelling in the forum
    I can not do (vla- or (vlax- even after (vl-load-com) or start any *.dvb in any way
    "old-fashioned" lisp and (vl- is ok
    kennet
    2002-05
    1,706
    Thread closed, AutoCAD killed and reinstalled. No good explanation, probably main problem in registry. Thank´s for thinking.
  1. Arx won't load
    By damitch725808 in forum ARX
    Last Post: 2012-01-31, 05:04 AM
  2. How to load an app ?
    By nigeld in forum Revit - API
    Last Post: 2010-08-24, 02:52 AM
  3. (vl-load-com)
    By gfreddog in forum AutoLISP
    Last Post: 2008-01-04, 12:13 AM
  4. LISP load order in relationship to CUI load order
    By Steve_Bennett in forum AutoCAD CUI Menus
    Last Post: 2007-01-19, 05:43 PM
