Thread: Revit/RAM error - Start Level/End Level Offset - Parameter is Read Only.
    100 Club lzaras's Avatar
    2001-03
    United States, next to a Lake
    136
    Default Revit/RAM error - Start Level/End Level Offset - Parameter is Read Only.
    I asked over at Adesk, but also wanted to ask you experts here...
    I have an engineer that is using RAM as the analysis program for his project. It's a painful learning process, but it seems he's almost there! Currently, he's getting a 1 1/2 pages of errors and we'd like to know if any of you have any suggestions in getting them cleaned up.
    \10/6/2008 10:46:24 AM - Begin import from "(project folder and project name)"
    10/6/2008 10:46:24 AM - Imported using RAMDataAccess v12.1
    10/6/2008 10:46:24 AM - Begin reading RSS file
    10/6/2008 10:46:27 AM - Finished reading RSS file
    10/6/2008 10:46:27 AM - Getting model differences
    10/6/2008 10:46:30 AM - Updating Revit model
    10/6/2008 10:56:52 AM - Error: Unable to update Start Level Offset for Revit Beam 264797. Parameter is Read Only.
    10/6/2008 10:56:52 AM - Error: Unable to update End Level Offset for Revit Beam 264797. Parameter is Read Only.
    10/6/2008 10:56:52 AM - Error: Unable to update Start Level Offset for Revit Beam 264799. Parameter is Read Only.
    10/6/2008 10:56:52 AM - Error: Unable to update End Level Offset for Revit Beam 264799. Parameter is Read Only.
    10/6/2008 10:56:56 AM - Error: Unable to update Start Level Offset for Revit Beam 265006. Parameter is Read Only.
    10/6/2008 10:56:56 AM - Error: Unable to update End Level Offset for Revit Beam 265006. Parameter is Read Only.
    10/6/2008 10:56:58 AM - Error: Unable to update Start Level Offset for Revit Beam 265482. Parameter is Read Only.
    10/6/2008 10:56:58 AM - Error: Unable to update End Level Offset for Revit Beam 265482. Parameter is Read Only.
    10/6/2008 10:56:58 AM - Error: Unable to update Start Level Offset for Revit Beam 265484. Parameter is Read Only.
    10/6/2008 10:56:58 AM - Error: Unable to update End Level Offset for Revit Beam 265484. Parameter is Read Only.
    10/6/2008 10:57:10 AM - Error: Unable to update Start Level Offset for Revit Beam 301862. Parameter is Read Only.
    10/6/2008 10:57:10 AM - Error: Unable to update End Level Offset for Revit Beam 301862. Parameter is Read Only.
    10/6/2008 10:58:36 AM - Error: Unable to update Start Level Offset for Revit Beam 413345. Parameter is Read Only.
    10/6/2008 10:58:36 AM - Error: Unable to update End Level Offset for Revit Beam 413345. Parameter is Read Only.
    10/6/2008 10:58:37 AM - Error: Unable to update Start Level Offset for Revit
    Beam 413395. Parameter is Read Only.
    10/6/2008 10:58:37 AM - Error: Unable to update End Level Offset for Revit Beam 413395. Parameter is Read Only.
    10/6/2008 10:59:09 AM - Finalizing Import
    10/6/2008 10:59:12 AM - Refreshing Model
    10/6/2008 10:59:26 AM - Model Imported With: 96 errors and 2 warnings.
    Though it looks like the import from RAM is working and "refreshing model," none of the beam sizes have updated.
    This "Start Level Offset" and "End Level Offset"... RAM is telling us that the Parameter is Read Only. Is there a way to override this so that RAM can update the Revit Model?
    2015-10
    Escondido, CA
    91
    Default Re: Revit/RAM error - Start Level/End Level Offset - Parameter is Read Only.
    Make sure your elements aren't pinned. That will prevent the start and end level offsets from being edited.
    2006-09
    442
    I have seen that error message before in our workings with Ram, and it seems that ram wanted up update the start and end offsets for beams that are part of a beam system. Which are pinned. In our experience it was just an error message that we ignored, as the beams sizes still got updated.
    I have a feeling that it has something to do with coordinate or elevation rounding between Revit and Ram, and that ram is trying to move the beam a very small amount, but can't because it's part of a beam system. Only a guess.
    2001-12
    Irvine, CA
    7,567
    My first thought was beams in Beam Systems...they are defined by the beam system and the external app may not be able to "fix" those because they a "pinned" by the system.
  1. Pipe Filter by level offset - Reference Level Offset
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2013-04-02, 04:05 AM
  2. Replies: 1
    Last Post: 2012-07-03, 06:09 PM
  3. Revit objects loosing level parameter
    By whilgendorf in forum NavisWorks - General
    Last Post: 2009-05-04, 06:52 PM
  4. Beam Start/End Level Offsets
    By geposton in forum Revit Structure - Families
    Last Post: 2009-02-13, 08:05 PM
  5. revit 2009 - level tag an line gone in section, level still there
    By samov in forum Revit Architecture - General
    Last Post: 2008-05-16, 03:51 PM
