Results 1 to 10 of 19
Thread: How do I enter the degrees symbol - 'o'
    2008-09
    80
    Default How do I enter the degrees symbol - 'o'
    That is to say the small 'o' that goes at the top right of the number.
    Try as I might I cant find it mentioned in 'help'.
    Many thanks
    RD
    AUGI Addict Railrose's Avatar
    Abilene, TX
    1,181
    Default Re: How do I enter the degrees symbol - 'o'
    When typing text, type %%D.
    Give people a job worth doing, the tools to do it, recognition of a job well done & get out of the way.
    2008-09
    80
    Quote Originally Posted by Railrose View Post
    Yaahhoooo. Thank you very much
    Abilene, TX
    1,181
    You're very welcome.
    Abilene, TX
    1,181
    Here is a list of %% text tweaks.
    %% c = diameter
    %% d = degree
    %% o = overline
    %% p = +/-
    %% u = underline
    2008-09
    80
    %% c = diameter
    %% d = degree
    %% o = overline
    %% p = +/-
    %% u = underline
    Even better. Cheers
    Is it possible to change the width and length of a layout after it's been started? I know you can enter points outside of the L/W dimensions but how do you make the grid fit a larger size? Thanks again.
    RD
    Abilene, TX
    1,181
    Do you mean plotting area on a layout tab? If so, you can do a page set-up & change your printer settings to accommodate different page sizes.
    Earth
    9,804
    Quote Originally Posted by ukdodger View Post
    ALT+248 (on the numpad) should work also. I used this below.
    N15°57'18"W
    R.K. McSwain | CAD Panacea |
    2008-09
    80
    Er.. Dont think so. When you start a drawing from scratch you enter the width and length, in my case 400 x 500. I now find that is too small. I want to make it 400x 800. It's not that I want to plot it to paper I want the grid lines to extend to 800. Hope this makes sense. Thanks
    RD
    2008-09
    80
    N15°57'18"W
    I wonder why just saying just 'thanks' is considered too short to post the message. Most odd.
    But Thanks.
  1. 2012: Degrees symbol in text
    By westcad in forum Revit Architecture - General
    Last Post: 2011-09-05, 06:06 AM
  2. Replies: 4
    Last Post: 2008-01-13, 07:56 PM
  3. Replies: 1
    Last Post: 2006-06-13, 06:36 PM
  4. How to enter Degrees Minutes Seconds?
    By Jason in forum Revit Architecture - General
    Last Post: 2004-12-02, 09:33 PM
