Thread: Use Parameters in dimension expression
    Wish List Administration
    2006-03
    1,102
    Default Use Parameters in dimension expression
    Summary: Be able to link an existing iPart/iAssembly parameter to dimension in another column.
    Description: Add iPart/iAssembly table dimension
    How Used: You can create an iPart/iAssembly table that has the parameters in it. Add a Dimension that is tied to the column in the table. This will keep from having to override the Dimension. If it is tied directly to the table (like ballons) then errors are reduced.
    Feature Affinity: Drawing Manager
    Submitted By: jon selzer on September 2, 2008
    2011-08
    4,581
    Exclamation Re: Use Parameters in dimension expression
    This wish has been reported as granted and already in the software.
    2011-08
    4,581
    The wish has already been granted. This thread is closed to further posts.
    2011-08
    4,581
  1. 2014: Duct Fittings - Default dimension parameters
    By slovenc0417 in forum Revit MEP - General
    Last Post: 2014-04-18, 12:17 AM
  2. Need help with dimension parameters
    By EddieFromDc in forum Revit MEP - Families
    Last Post: 2012-12-17, 03:50 PM
  3. some help with a macro expression
    By Doodlemusmaximus in forum AutoCAD Customization
    Last Post: 2011-03-21, 10:49 AM
  4. Help with expression
    By fclao in forum AutoLISP
    Last Post: 2010-02-24, 10:52 PM
  5. Where are the dimension Parameters?
    By Dave F. in forum Revit Architecture - Families
    Last Post: 2009-03-03, 04:26 PM
