Thread: Can't Import dwg with xref exported revit dwg
    2007-03
    Salt Lake City
    360
    Default Can't Import dwg with xref exported revit dwg
    We're working with a consultant by exporting dwgs from our Revit file. When I attempt to import/link their file, which has our exported dwg as an xref, I get a "can't import file" error. When I unload or delete the xref'd file then it works.
    I guess this is fine, as I really only need what they've drawn on top of our file, but why do I get this error? Do I only get this error because the xref file is from the revit file? I don't get the error in other dwg files with xref'd ACAD files.
    100 Club MNsnowtaTy's Avatar
    2007-06
    Minnesota
    142
    Default Re: Can't Import dwg with xref exported revit dwg
    I believe it is because you have exported the Revit File to CAD, and then now you are just importing what you already had exported out. So you would just want to bring in the new work.
  1. import de revit, xréf, problèmed'affichage
    By antoinesix in forum Français - AutoCAD / AutoCAD LT - Général
    Last Post: 2009-10-13, 01:16 PM
  2. Replies: 2
    Last Post: 2009-09-15, 04:52 PM
  3. Cleaning up exported Revit model
    By Arnel Aguel in forum Revit - Rendering
    Last Post: 2006-10-01, 02:13 PM
  4. Rendered in and Exported right from Revit
    By JTF in forum Revit - Gallery
    Last Post: 2005-03-12, 01:17 PM
  5. Strange Models exported from Revit...why?
    By raphael.dunbar in forum Revit Architecture - General
    Last Post: 2004-12-21, 07:11 PM
