samov
How to make revit take into account dimensions of bricks when drawing a wall?!
Ok, let me elaborate, Most of you know that when using bricks on a facede requires quite a bit of "pre-dimensioning" in the design stage... especially corner and window areas. Is there are way to make revit "snap" to certain distances when using a certain kind of wall?
(normally you would make sure you dimension the walls as multiples of half the size of the brick... with different strategies depending on the design)
What is the best way/workflow to do it?
