Thread: Deferred Perpendicular Snap
    Edinburgh, Scotland
    2
    Unhappy Deferred Perpendicular Snap
    How do I get snap to go to deferred perpendicular as I am joining circular blocks together with lines & need shortest line between?. I am using 2004
    13,656
    Default Re: Deferred Perpendicular Snap
    Hi
    If I understand your question properly (unlikely knowing me), by using Perpendicular OSnap on first Circle (First Point), then Perpendicular OSnap on second Circle (Next Point), will produce the shortest line between the two Circles.
    Could you please post a simple drawing file showing exactly what you're after (would help me understand).
    Have a good one, Mike
    150700
    3,439
    Just to add to Mikes reply (and I believe he is correct) there is a link in another thread that refers to some of the new features for 2005, and included in there is a discussion about deferred perpendicular and deferred tangent snaps. It is in the Tips and Tricks for AutoCAD 2005 link
    I was watching this to learn more about the text masking mtext and dims, but the part about the snaps was in there as well. Hope this helps
    Edinburgh, Scotland
    2
    Smile Re: Deferred Perpendicular Snap
    I was using Plines. This doesn't work for some reason. It works perfectly with lines so I will do it that way & convert when finished.
    Thanks for all your suggestions
  1. Perpendicular 2D snap to line
    By Tom Beauford in forum AutoLISP
    Last Post: 2013-05-17, 03:31 PM
  2. Multileader snap perpendicular to arc
    Last Post: 2012-06-12, 06:00 PM
  3. Perpendicular & nearest won't snap to arc
    By gadjet in forum AutoCAD General
    Last Post: 2007-05-08, 07:13 AM
  4. Replies: 5
    Last Post: 2006-11-09, 07:19 PM
  5. Perpendicular Object Snap
    By SHEILA in forum ACA General
    Last Post: 2004-10-06, 06:41 PM
