Thread: Unable to save edited Attribute Text
    2008-09
    10
    Cool Unable to save edited Attribute Text
    A particular attribute of an inserted block (title block) reverts back to default text (ie.###) every time I save the drawing after editing it.
    I can find no difference in the settings of the attribute compared to the others in the same block.
    Does anyone know the cause of this happening?
    2000-01
    Seattle WA USA
    5,859
    Default Re: Unable to save edited Attribute Text
    You fail to mention what field expression you are using.
    Sort of like asking the auto mechanic on the phone what wrong with the car because it is making a funny noise, and you don't even mention what the noise sounds like.
    R. Robert Bell
    Design Technology Manager
    Stantec
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Which version of AutoCAD was this created with? Does it use Multi-Line Attributes? I have seen this with Fields that reference Sheet Set Placeholder text.
  1. 2013: Text indenting changes each time it's edited
    By trialbyfire in forum Revit Structure - General
    Last Post: 2017-05-25, 03:37 PM
  2. Updating Text Mask once Text has been edited
    By r_soula in forum AutoCAD General
    Last Post: 2007-06-05, 03:05 AM
  3. AutoCAD 2006 - Unable to move Attribute Text via Grips
    By andrew.90224 in forum AutoCAD General
    Last Post: 2007-04-02, 01:00 PM
  4. Replies: 3
    Last Post: 2006-04-04, 05:46 PM
  5. Marking Edited TEXT/MTEXT Entities
    By relysoft in forum AutoLISP
    Last Post: 2004-12-06, 10:15 PM
