Results 1 to 10 of 13
Thread: exporting revit file into sketchup
    2008-10
    4
    Default exporting revit file into sketchup
    hey there everybody.first time on here.i just have a question.i'm trying to do a google earth visualization for a project im doing.how do i get a revit file into sketchup.i tried exporting as a 3ds file,but revit didnt have that format.What do i do.One more thing,with the file i am exporting,will i be able to keep the material properties?
    thanks guys
    All AUGI, all the time Norton_cad's Avatar
    2016-02
    Sydney, Australia
    511
    Default Re: exporting revit file into sketchup
    Export a DWG format. Sketckup understands DWG files okay.
    I think your materials settings will be lost, as Sketchup dosn't understand other materials.
    I think a material translation needs to be added to the Sketchup import/export command.
    Ohm's Law - Electricity follows the path of least resistance.
    Regards,
    Mark Norton,
    2008-10
    4
    how about the 3d model from revit to sketchup,thats where the problem is
    2003-11
    442
    You have to be in a 3D view in Revit when you export to dwg. Materials will not transfer to SketchUp.
    2003-04
    Chino, CA
    4,754
    If you want to go Revit to Google Earth, why don't you use the Revit Google Earth Extension which will not only export your model to a Sketchup format, but it will place it in the correct site and orientation in Google Earth.
    Scott D Davis
    Sr AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
    2006-04
    Scott- I don't understand where the Export to Google Earth option is in Revit.
    Can you please advise.
    We have both Revit 2009 and 2010.
    thank you for any help.
    Jim
    2003-04
    Chino, CA
    4,754
    This is a plug-in for Revit that you must download and install from the Subscription Center. Log into Subscripton Center (www.autodesk.com/subscription), and look for the:
    Globe Link for Autodesk Revit 2010
    or
    Globe Link for Revit 2009
    Scott D Davis
    Autodesk, Inc.
    4
    Hello and thanks in advance for any advice.
    I've installed Globe Link and while exporting to a kmz file everything appears to go fine on the Revit end of things. However, if I open Sketchup and attempt to import, I come up empty handed. Sketchup takes some time and behaves as if it was importing something but at the end of the process nothing has happened. I'm using 2010 on a 32-bit XP.
    2008-07
    1 members found this post helpful.
    Here is one way to pull your Revit model into Sketchup:
    1. While in a 3D view turn the "Section Box" on (found in view properties) and compress the section box to just the area you want to study in Sketchup. This may be the whole model or just a piece (an entry alcove, one exterior elevation, etc). Depending on the speed of your computer and the size of your Revit model, you may want to narrow the scope of the exported model in order to decrease file size.
    2. File - Export - CAD formats. In the "Export Options", under "Solids" choose "Export as ACIS solids". This will export Revit objects/elements as components so that they don't get too sticky when working in Sketchup.
    3. Once your export is saved, open Sketchup and "import" the dwg. The file will import with DWG layers as Sketchup layers, separating your glazing from your doors, etc.
    4. Change your layer setting in Sketchup to "color by layer". This gives you universal control over the color/material of all of your glazing, doors, etc. Change the color/transparency of each layer to your liking.
    This isn't a perfect process but I find it works well to take advantage of the more design-friendly interface of Sketchup and to produce quick color images for clients.
    2007-09
    North Carolina
    66
    Quote Originally Posted by chris.74844 View Post
    I had the same issue with Export to Google Earth, but haven't had the time to play with it more. Any help on this front would be greatly appreciated.
  1. 2014: Converting a SketchUp file to a schedulable Revit Family
    By drubinoff in forum Revit Architecture - General
    Last Post: 2015-05-05, 05:59 PM
  2. Link a Sketchup file (via dwg) to Revit
    By dc.109967 in forum Revit Architecture - General
    Last Post: 2009-02-09, 03:36 PM
  3. exporting revit files into sketchup
    By dac-sektion in forum Revit - Platform
    Last Post: 2008-10-29, 10:50 PM
  4. Exporting to SketchUp...best practices?
    By FWSchreck in forum Revit Architecture - General
    Last Post: 2008-04-10, 12:23 AM
  5. Exporting sketchup to Max
    By depth3d in forum 3ds Max - General
    Last Post: 2007-10-30, 09:20 AM
