Thread: Crash when Inserting aerial photo JPEG2000 format
    16
    Smile Crash when Inserting aerial photo JPEG2000 format
    When I try to insert an aerial photo that is in JP2 format into a map using Raster Design and Map (both 2008 and 2009), I get a fatal error - unhandled exception. The aerial photo is from Indiana Spatial Data Portal - http://www.indiana.edu/~gisdata/statewide/08naip.html
    My computer has XP Pro with Nvidia Quadro FX3500 with 250MB memory onboard.
    Is this a problem with JPEG 2000 format and AutoCAD or is this unique to my system?
    Thanks!
    Dave Ralston
    South Eastern US, exact location unknown
    1,376
    Default Re: Crash when Inserting aerial photo JPEG2000 format
    I get the same fatal error when I tried with onr from the side you linked. Make sure you sent off the CER and maybe a fix will be down the road.
    J. Murphy
    AKA
    Murph
    The former AutoCAD MAP3D Power User
    16
    Smile Re: Crash when Inserting aerial photo JPEG2000 format
    Thanks for checking the JP2 image. What is the next step in finding a fix?
    Dave Ralston
    1,376
    You can file a support request with the subcription center, but after checking a few others jp2 format they load ok in Map3D, it may be the image you d/l and unzipped may be corrupt. I tried opening the one I d/l in another image viewr and got a error also. If you want to try try a sample image from here http://www.microimages.com/gallery/jp2/
    J. Murphy
    AKA
    Murph
  1. Aerial Photo
    By chet.smith in forum Raster Design - General
    Last Post: 2008-07-29, 02:26 PM
  2. Drape an Aerial Photo
    By anthony.64830 in forum AutoCAD General
    Last Post: 2005-05-24, 03:54 PM
  3. DWG contain aerial photo, it crashed while zoon in and out.
    By ratha99 in forum Raster Design - General
    Last Post: 2005-03-19, 12:23 AM
  4. Trouble plotting aerial photo in Black and White
    By sreelfs in forum AutoCAD Plotting
    Last Post: 2004-07-14, 05:56 PM
